²úÆ·Ãû³Æ£º IX945GSE
ÐÍ ºÅ£º IX945GSE
Æ· ÅÆ£º 1044
CPU
Supports Intel® FCBGA8 45nm Atom™ N270 Processor
FSB
533 MHz
BIOS
Award 16 Mb SPI BIOS
System Chipset
Intel® 945GSE + ICH7-M Chipset
I/O Chip
Winbond W83627DHG-A
System Memory
One 200-pin SO-DIMM up to 2GB Single
Channel DDR2 533 SDRAM , non-ECC
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 x PCI (PCI Rev. 2.3 compliant) supports 3 PCI master
S3/S4
yes
TPM
TPM1.2 (Infineon TPM chip 9635 TT 1.2 on board) LAN (PME / RPL)
Wake up on LAN or Ring
YES( 1 x fan connector)
I/O
MIO
1 X EIDE, 2 X SATA,4 X RS-232,1 X K/B,1 X Mouse
USB
6XUSB 2.0
DIO
16-bit General Purpose I/O for DI and DO
Display
Chipset
Intel® 945GSE GMCH integrated Graphics Media Accelerator 950
Display Memory
Intel® DVMT 3.0 supports 224 MB video memory
Max Resolution
CRT: Support up to QXGA (2048 x 1536)
LVDS: Support up to UXGA (1600 x 1200)
Dual Display
dual view, 2-CH LVDS, DVI
VGA
Yes , on board GMA 950,Support for CRT resolutions up to QXGA
LVDS
Support for dual-channel LVDS resolutions up to UXGA 18bit Single/Dual channel
LVDS Backlight Power Connector
Yes
DVI
Yes,DVI-D
Audio
Audio Codec
Realtek® ALC888, 5.1 HD Audio
Audio Interface
Mic in, Line in, Line out
Audio Amplifier (W)
TPA3005D2 Stereo 6Watt
Ethernet
LAN 1
Realtek RTL8111C Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 1 x VGA port/ 1 x DVI port / 2 x COM Port/ 2 x RJ45 port / 4 x USB 2.0/1.1 / 1 x Audio Jack (3 ports)
Internal I/O Connector
2 x power COM port
1 x 2x10-pin ATX Power connector
1 x CPU Fan connector
1 x Power Fan connector
1 x USB connectors support additional 2 USB ports
1 x LVDS connector
1 x LVDS invertor connector
1 x IDE connector
2 x SATA connectors
1 x digital IO header
1 x Front panel header
1 x S/PDIF Out Header
1 x Audio amplifier connector
1 x Front Audio connector
1 x Mini-PCI Express
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60¡æ (32~140¨H)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX945GSE
Intel® 945GSE Supports Intel® FCBGA8 45nm AtomTM N270 Mini ITX Main Board with VGA,2-CH LVDS,DVI,Audio, Gb LAN, 4 COM,
6 USB 2.0, 1 PCI, 1 Mini-PCIe, 8-bit DIO & 6W AMP
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
