| CPU |
Onboard Intel uFC-BGA 479 Celeron M 600MHz / 1GHz CPU Zero Cache |
| FSB |
400MHz |
| BIOS |
Award 4 Mb Flash BIOS |
| System Chipset |
Intel® 82910GMLE GMCH/82801FBM ICH6-M |
| I/O Chip |
Winbond W83627EHG-A |
| System Memory |
Two 240-pin DIMM socket supports up to 2 GB DDR2 400 SDRAM |
| SSD |
One CompactFlash Type I/II socket |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring CPU temperature and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
One PCI slot (PCI Rev. 2.2 compliant) supports 3 PCI master |
| S3 |
S3 Support |
| SmartFan Control |
Speed Cruise Mode |
| I/O |
| MIO |
1 xEIDE (Ultra DMA 100), 2 x SATA, 4 x RS-232, 1 x K/B, 1 x Mouse |
| IrDA |
115k bps, IrDA 1.0 compliant |
| USB |
8 x USB 2.0 |
| DIO |
16-bit General Purpose I/O for DI and DO |
| Display |
| Chipset |
Intel® 82910GMLE GMCH integrated Graphics Media Accelerator 900 |
| Display Memory |
Intel® DVMT 3.0 supports up to 128 MB video memory |
| Resolution |
2048 x 1536 @ 32 bpp (85 Hz) |
| Dual Display |
CRT + LVDS, or CRT + DVI-D |
| LVDS |
Intel® 910GMLE supports Single channel 18-bit / Dual-channel 36-bit LVDS |
| DVI |
Chrontel CH7307C DVI transmitter up to 165M pixels/second |
| Audio |
| Chipset |
Intel® 82801FBM ICH6-M |
| Audio Code |
Realtek ALC655 supports 5.1 CH Audio |
| Audio Interface |
Mic in, Line in, Line out |
| Audio Amplifer |
TPA3005D2 Stereo 5 Watt per channel |
| Ethernet |
| LAN1 |
Realtek RTL8110SC PCI-E 1000Base-T Gigabit Ethernet Controller |
| Back Panel I/O Port |
* 1 x PS/2 Keyboard * 1 x PS/2 Mouse * 2 x RS-232 * 1 x VGA port * 1 x DVI por * 4 x USB 2.0/1.1 * 1 x RJ45 Port * 5.1 CH Audio I/O (3 jacks) |
| Internal I/O Connector |
* 2 x USB connectors support 4 USB ports * 1 x 20-pin ATX Power connector * 1 x IDE 40-pin connector for two devices * 2 x COM port header * 2 x SATA connectors * 1 x Front panel audio connector |
| Mechanical & EnvironmentalI |
| Power Type |
ATX |
| Operating Temperature |
0~60¡ãC (32~140¡ãF) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
6.69" x 6.69" (170 mm x 170 mm) |
| Weight |
0.88 lbs (0.4 Kg) |
