| CPU |
Intel uFC-LGA 775 socket supports Pentium D / Pentium 4 / Celeron D with 65 nm process technology |
| FSB |
1066/800/533 MHz |
| BIOS |
Award 4Mb Flash BIOS |
| System Chipset |
Intel 82945G GMCH/ ICH7 |
| I/O Chip |
Winbond(R) W83627EHG-A |
| System Memory |
Four 240-pin DIMM sockets support up to 4 GB Dual Channel DDR2 400/533/667 SDRAM |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
One PCI Express X16, one PCI Express X1, two PCI slots (PCI Rev. 2.2 compliant) |
| I/O |
| MIO |
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD , 1 x LPT, 2 x RS-232, 1x K/B, 1 x Mouse |
| USB |
8 x USB 2.0 ports |
| DIO |
| IEEE-1394A |
| Display |
| Chipset |
Intel 82945G GMCH integrated Graphics Media Accelerator 950 |
| Display Memory |
Intel DVMT 3.0 supports 224 MB video memory |
| Max. 3D Resolution |
2048 x 1536 @ 32 bpp (85 Hz) |
| Dual Display |
| VGA/LCD Interface |
PCI-E X16 VGA interface |
| LVDS |
Through ADD2 LVDS Card (Customized BIOS required) |
| DVI |
Through ADD2 DVI Card (Customized BIOS required) |
| TV-out |
Through ADD2 TV-Out Card (Customized BIOS required) |
| Built-in Touch Screen (Optional) |
| Chipset |
| Touch Screen Interface |
| Audio |
| Chipset |
Intel ICH7 |
| AC97 Codec |
Realtek ALC 882, 8 CH High-Definition Audio Codec |
| Audio Interface |
Mic in, Line in, CD Audio in, Line out |
| Ethernet |
| LAN 1 |
Intel 82573L Gigabit LAN |
| LAN 2 |
| Ethernet Interface |
1000Base-T Fast Ethernet compatible: Intel 82573 |
| Back Panel I/O Port |
1 x PS/2 Keyboard 1 x PS/2 Mouse 1 x Parallel port 1 x Serial port 1 x VGA port 1 x RJ45 port 4 x USB 2.0/1.1 Audio I/O (6 jacks) |
| Internal I/O Connector |
3 x USB connectors support additional 6 USB ports 1 x 24-pin ATX Power connector 1 x 4-pin ATX 12V Power connector 1 x Floppy disk drive connector 1 x IDE connector for two devices 1 x COM connector 1 x Chassis intrusion connector 1 x CD audio in c |
| Mechanical & Environmental |
| Power Requirement |
+5 V @ 6.25 A, +12 V @ 4.10 A, +3.3 V @ 0.85 A (with Intel Core 2 Duo E6300 1.86 GHz & 512 MB DDR SDRAM) |
| Power Type |
ATX |
| Operating Temperature |
0~50¡ãC (32~122¡ãF) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
9.6'' x 9.6'' (243.84 mm x 243.84 mm) |
| Weight |
0.88 lbs (0.4 kg) |
