²úÆ·Ãû³Æ£º BV945GL
ÐÍ ºÅ£º BV945GL
Æ· ÅÆ£º 1044
CPU
Intel® uFC-LGA 775 socket Supports Core 2 Duo Pentium® D / PentiumR 4 / Celeron® D with 65nm process technology
FSB
1066/800/533 MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel® 82945G GMCH/ ICH7
I/O Chip
Winbond W83627EHG-A
System Memory
Four 240-pin DIMM sockets support up to 4 GB
Dual Channel DDR2 667/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, one PCI Express X1,
five PCI slots (PCI Rev. 2.2 compliant)
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD,
1 x LPT, 1 x RS-232, 1 x RS-232/422/485,
1x K/B, 1 x Mouse
USB
8 x USB 2.0 ports
Display
Chipset
Intel® 82945G GMCH integrated Graphics
Media Ac-celerator 950
Display Memory
Intel® DVMT 3.0 supports 224 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75 Hz)
VGA/LCD Interface
PCI-E X16 VGA interface
LVDS
Through ADD2 LVDS Card
(Customized BIOS required)
DVI
Through ADD2 DVI Card
TV-out
Through ADD2 TV-out Card
Audio
Chipset
Intel® ICH7
AC97 Codec
Realtek ALC 888, 7.1 CH High-Definition
Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Ethernet
LAN 1
Intel® 82573L Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 1 x Parallel port
* 1 x Serial port
* 1 x VGA port
* 1 x RJ45 port
* 4 x USB ports
* Audio I/O (3 jacks)
Internal I/O Connector
Internal I/O Port
* 2 x USB connectors support
additional 4 USB ports
* 1 x 24-pin ATX Power connector
* 1 x 4-pin ATX 12V Power connector
* 1 x Floppy disk drive connector
* 1 x IDE connector for two devices
* 1 x COM connectors
* 1 x Chassis intrusion connector
Mechanical & Environmental
Power Requirement
+5 V @ 4.26 A, +12 V @ 10.12 A,
+3.3 V @ 722 mA (with Intel® Core 2
Duo E6400 2.13 GHz & 1 GB*2
DDR2 SDRAM)
Power Type
ATX
Operating Temperature
0~60¡ãC (32~140¡ãF)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
BV945GL
Intel® LGA775 Core 2 Duo / Pentium® D
Pentium® 4 / Celeron® ATX Motherboard
with VGA, Audio, Gb LAN, 2 COM,
8 USB 2.0, 1 PCI-E X16, 1 PCI-E X1,
& 5 PCI
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
