Form Factor |
Half-size PISA bus CPU Card |
CPU |
Intel Atom N270 1.6GHz processor
L2 cache: 512KB
Package type: FCBGA8
Front side bus: 533MHz |
Memory |
1 x 200-pin DDR2 400/533 SO-DIMM SDRAM up to 2GB |
Chipset |
Intel 945GSE & ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel integrated extreme GMA 950 (Graphic Media Accelerator) Technology |
Video Memory |
Up to 224MB shared with system memory |
LVDS Interface |
Onboard 18-bit dual channel LVDS interface
Optional 24-bit dual channel LVDS interface
( HE-875PXG2 / HE-875PXG ) |
DVI Interface |
Optional DVI interface ( HE-875PDG2 / HE-875PDG ) |
Serial ATA Interface |
2 x SATA interface with 150MB/s transfer rate |
IDE Interface |
1 x UltraATA33 IDE channel up to 2 ATAPI devices with IDE 44-pin connector |
Solid State Disk |
IDE supports 44-Pin DiskOnModule with +5V power supply
1 x Compact Flash Type II socket |
Audio Interface |
Intel integrated ICH7M with AC97 Audio |
LAN Interface |
2 x Gigabit LAN |
GPIO Interface |
Onboard programmable 8-bit Digital I/O interface |
Extend Interface |
1 x Mini-PCI socket and 1 x Compact Flash Type II socket |
Internal I/O Port |
1 x IDE, 2 x SATA, 1 x FDD, 1 x LPT, 6 x USB, 1 x CDIN,
1 x AC97 Audio connector, 1 x GPIO, 1 x IrDA,
1 x Onboard 5-pin AT keyboard Port, 1 x RS232,
1 x RS232/422/485, 1 x HDTV, 1 x LVDS,
1 x 5-pin LCD inverter connector,
1 x DVI ( HE-875PDG2 / HE-875PDG ) |
External I/O Port |
COM, LAN, DB15 VGA, PS/2 Keyboard & Mouse |
Power Requirement |
+5V, +12V DC input & 5VSB Requirement, Onboard 4-pin power & 3-pin ATX connector |
Board Dimension |
185mm x 127 mm (L x W) |
Temperature |
Operating within 0~60ºC
Storage within -20~85ºC |
