WIZnetÒÔÌ«ÍøÍø¹ØÄ£¿é±È½Ï
WIZ110SR |
WIZ105SR |
WIZ110SR |
WIZ120SR |
Hardware
UTP Pin Header |
RJ45 Connector |
RJ45 Connector |
UTP Pin Header |
| TTL Pin Header |
DB9 connector |
TTL Pin Header (2 Serials) |
Common Key Features
- W5100 Embedded - 10/100Mbps Ethernet Interface - Max. 230Kbps Serial Interface - Easy & Powerful Configuration Program - Support: TCP/UDP/IP/ARP/ICMP/MAC/Static/DHCP/PPPoE/DNS/Serial Command | |
¹æ¸ñ |
| Architecture |
TCP / IP |
W5100 |
| PHY |
Embedded in Included in W5100 |
| MCU |
ARM Cortex-M3 |
| Network |
Interface |
10/100 Base-T Ethernet (Auto detection) |
| Protocol |
TCP, UDP, IP, ARP, ICMP, IGMP, MAC, DHCP, PPPoE, DNS |
| Serial |
Port |
2 UART(RS232, 3.3V LVTTL) |
| Serial format |
Data bits: 7,8 Stop bits: 1,2 Parity: None, Odd, Even |
| flow control |
None, XON/XOFF, CTS/RTS |
| signal |
TXD, RXD, RTS, CTS, GND |
| Speed |
1200bps ~ 230Kbps |
| Software |
Remote Download and Configuration |
| Temperature |
0 ~ 70¡ãC (Operating), -40~85¡¯C (Storage) |
| Humidity |
10~90% |
| Power |
3.3V, 300mA(MAX) |
| Connector type |
1x14 2mm Pin header X 2 |
| Size |
50mm x 30mm x 8.85mm |
¶©»õÐÅÏ¢ |
| Model |
Description |
| WIZ120SR |
Serial-to-Ethernet Gateway Module |
| WIZ120SR-EVB |
Evaluation board for WIZ120SR (with WIZ120SR module) | |
