¹æ¸ñ |
Architecture |
TCP / IP |
W3150A+ |
PHY |
Multu ports PHY |
Network |
Interface |
10/100 Base-T Ethernet (Auto Detection) |
Support Internet Protocol |
TCP, IPv4, UDP, ICMP, ARP, PPPoE, IGMP |
Inlcude Ethernet Protocol |
DLC, MAC |
Dimension |
Connector Type |
two 2.00mm pitch 2 x 25 header pin |
| PCB Throughhole |
None |
Input Voltage |
3.3V Internal Operation, 5V Tolerant I/Os |
Temperature |
Operation: 0 ~ 70 (Centigrade Degree) |
Power Consumption |
3.3V with 5V I/O signal tolerance |
NM7010B+ Óë WIZ850SW ±È½Ï
NM7010B+ |
WIZ850SW |
| Hardware |
W3150A+, PHY, RJ45 |
W3150A+, Multiport PHY |
| Socket |
4 |
| MCU Interface |
BUS (8 bits) & SPI |
Pin Header (Pitch)
Two 14X2 (2 mm)
Two 25X2 (2 mm) |
Network Interface
RJ45
4 ports UTP, 1 MII/RMII |
Network Port
Single port Network module
Multiport (6) Switch module | |
¶©»õÐÅÏ¢ |
| Model |
Description |
| WIZ850SW |
Multi ports switching network module | |
