CPU type |
VIA Eden(V4) ULV 1 GHz nano BGA2 400 pin, L1/L2 128K on die |
Front Side Bus |
400/533 MHz |
MB Chipset |
VIA CN700 + VIA VT8237R Plus |
Graphics |
Integrated with VIA CN700 Shared system memory up to 64MB MPEG-2 hardware VLD |
LVDS |
Supports data format of 24 bits/48 bits |
Memory |
1* DDR II SDRAM 533/400 (max. 1GB) |
IDE |
Ultra DMA-133/100/66 transfer protocols 1x 40 pin 2.54mm, 1x44 pin 2.0mm Support Compact Flash card type II for ATA interface |
Audio |
AC-Link for Audio CODEC, AC¡¯97 2.1 |
LAN |
1* Realtek RLT8100C 10/100 Mbps |
IO function |
4 x RS232, 1xRS232/422/485 pin header Supports Hardware Monitor Controller Supports IrDA 1.0/ASKIR protocol Supports PS2 keyboard and mouse |
USB |
2* USB 2.0(external) & 5 USB 2.0(internal) |
Touch Screen |
USB interface Touch screen controller Supported 4-, 5-, 8- wire Analog Resistive touch screen. Resister range from 200 to 1000 Ohm USB 1.1full speed sample rate (max. 300 point/s) |
Expansion interface |
1* Mini PCI for only PCI rev: 2.2 interface |
SATA |
One channel connector SATA drive transfer rate is capable up to 150MB/s |
DIO & WDT |
Hardware digital Input & Output, 8xDI / 8xDO Hardware Watch Dog Timer, 0~255 sec programmable |
Power |
On board DC +12V convert to +3.3V/+12V/+5V for system |
Dimension |
200*150 mm(MB) 76.6H x 280W x 200.4D mm(chassis) 9H x 310W x 230D mm(10.4" panel) |
Operating Temperature |
0~40¡ãC (with CF card or 2.5" HDD) Please upgrade the hard drive to industrial grade for better temperature performance |
Operating Humidity |
5~95% @ 60¡ãC, non-condensing |
