Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 17´çÎÞ·çÉÈÈË»ú½çÃæ
²úÆ·Ãû³Æ£º 17´çÎÞ·çÉÈÈË»ú½çÃæ
ÐÍ ºÅ£º 17´çÎÞ·çÉÈÈË»ú½çÃæ
CPU type
VIA Eden(V4) ULV 1GHz nano BGA2 400 pin, L1/L2 128K on die
Front Side Bus
400/533 MHz
MB Chipset
VIA CN700 + VIA VT8237R Plus
Graphics
Integrated with VIA CN700
Shared system memory up to 64MB
MPEG-2 hardware VLD
LVDS
Supports data format of 24 bits/48 bits
Memory
1* DDR II SDRAM 533/400 (max. 1GB)
IDE
Ultra DMA-133/100/66 transfer protocols
1x 40 pin 2.54mm, 1x44 pin 2.0mm
Support Compact Flash card type II for ATA interface
Audio
AC-Link for Audio CODEC, AC¡¯97 2.1
LAN
1* Realtek RLT8100C 10/100 Mbps
IO function
4 x RS232, 1xRS232/422/485 pin header
Supports Hardware Monitor Controller
Supports IrDA 1.0/ASKIR protocol
Supports PS2 keyboard and mouse
USB
2* USB 2.0(external) & 5 USB 2.0(internal)
Touch Screen
USB interface Touch screen controller
Supported 4-, 5-, 8- wire Analog Resistive touch screen.
Resister range from 200 to 1000 Ohm
USB 1.1full speed sample rate (max. 300 point/s)
Expansion interface
1* Mini PCI for only PCI rev: 2.2 interface
SATA
One channel connector
SATA drive transfer rate is capable up to 150MB/s
DIO & WDT
Hardware digital Input & Output, 8xDI / 8xDO
Hardware Watch Dog Timer, 0~255 sec programmable
Power
On board DC +12V convert to +3.3V/+12V/+5V for system
Dimension
200*150 mm(MB)
99H x 424W x 339D mm(chassis)
9H x 452W x 356D mm(17.1" panel)
Operating Temperature
0~40¡ãC (with CF card or 3.5" HDD)
Please upgrade the hard drive to industrial grade for better temperature performance
Operating Humidity
5~95% @ 60¡ãC, non-condensing
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
