CPU type |
VIA Eden(V4) 500MHz 400pin L1 128KB, L2 128KB on die |
Front Side Bus |
400 / 533 MHz |
MB Chipset |
VIA CX700M |
Graphics |
Integrated with VIA CX700M Shared system memory up to 128MB MPEG-2/MPEG-4/WMV9 decoding mode |
Memory |
1* DDRII SODIMM (max. 1GB) |
CRT/HDTV |
Supports CRT resolution up to 1920x1200 Support TV resolution up to 1920x1080i Integrated with HDTV encoder Compliant with NTSC (M and J) or PAL (B, D, G, H, I, M, N and Nc) TV |
IDE |
Support Compact Flash card type II for ATA interface |
LAN |
1* Realtek RLT8100C 10/100 Mbps |
IO function |
3* RS232 + 2 RS422/485 pin header COM6 -RS232 is optional. CF slot shares COM 6 space Support Infrared SIR and FIR |
LVDS |
Support data format of 24 bits/ 48 bits |
Audio |
VIA VT1708/A HD Audio codec; Two channel SOUND Intel High Definition Audio Specification Rev.1.0 Compliant |
USB |
2* USB 2.0(external) & 4 USB 2.0(internal) |
SATA |
Supports up to Two channel SATA connectors Integrated SATA PHY supporting 1.5 Gbit/s and 3 Gbit/s transfer rate |
DIO & WDT |
Hardware digital Input & Output, 8xDI / 8xDO Hardware Watch Dog Timer, 0~255 sec programmable |
Touch Screen |
C8051F321USB interface Touch screen controller Supported 4-, 5-, 8- wire Analog Resistive touch screen. USB 1.1full speed sample rate (max. 300 point/s) |
Expand interface |
1* Mini PCI socket for only PCI rev 2.2 interface |
Power |
On board DC +12V¡À5% convert to +3V/+5V for system |
Dimension |
145 x 102 mm (3.5 inch) (MB) 56.5H x 408W x 265D mm(Chassis) |
Operating Temperature |
0~50¡ãC (CF card) / 0~45¡ãC (2.5" HDD) Please upgrade the hard drive to industrial grade for better temperature performance |
Operating Humidity |
5~95% @ 60¡ãC, non-condensing |
