²úÆ·Ãû³Æ£º
IPC-510 Ñлª¹¤¿Ø»ú£¬¹¤¿Ø»ú
ÐÍ ºÅ£º
IPC-510
IPC- 510
The IPC-510 is a 19"£» rackmount industrial computer chassis for mission-critical applications. This unit can accommodate a 14-slot PCI/ISA bus passive backplane or a standard ATX motherboard and supports versatile power supplies. A lockable door in the front secures the unit from any unauthorized access. One hot-swap filtered cooling fan maintains positive air circulation through the whole chassis. With its hold-down clamp and shock mounted drive brackets, the IPC-510 can withstand shock, vibration and dust found in harsh environments. |
| Ö÷ÒªÌØµã
| ÄÚÈݽéÉÜ |
¶©¹ºÐÅÏ¢
²úÆ·ÐòºÅ µµ°¸ÃèÊö
IPC-510BP-30ZE IPC-510BP With 300W P/S RoHS
IPC-510BP-25ZE IPC-510BP With 250W P/S RoHS
IPC-510BP-00XE IPC-510 BP Bare Chassis RoHS
