²úÆ·Ãû³Æ£º
PCI-1714u,ÑлªÊý¾Ý²É¼¯¿¨,¸ßËÙÊý¾Ý²É¼¯¿¨
ÐÍ ºÅ£º
Main Features
- 4 single-ended analog input channels
- 12-bit A/D converter, with up to 30 MHz sampling rate
- Programmable gain
- Onboard FIFO memory: 32,768 samples
- 4 A/D converters simultaneously sampling
- Multiple A/D triggering modes
- Programmable pacer/counter
- BoardID8482; switch
- Universal PCI Bus (support 3.3 V or 5 V PCI bus signal)
²úÆ·½éÉÜ£º PCI-1714U is an advanced high-performance data acquisition card based on the PCI bus. With a large FIFO of 32 K for each channel, the maximum sampling rate of PCI-1714U can get up to 30 MS/s, on each channel, with an emphasis on continuous, non-stop, high-speed, streaming data of samples to host memory. The low-cost PCI-1714UL offers 10MS/s on each channel at a stable rate, and has also been equipped with a universal PCI interface.
