²úÆ·½éÉÜ
The IPC-6908 is a high-end desktop/wallmount fault-resilient industrial computer chassis for mission-critical applications and harsh industrial computing environments. The IPC-6908 accepts up to 8 full-length cards and a 260-watt power supply. The front-accessible disk drive bay can hold two half-height and one 3.5" hard disk drives, and another 3.5" HDD can be mounted inside the case.
