Form Factor |
microATX Motherboard (244 x 244 mm) |
Processor |
Family: Intel® CoreTM 2 Quad / CoreTM 2 Duo / Celeron
Socket type: LGA775
FSB: 800/1066/1333MHz |
Memory |
4 x DDR3-800/1066MHz SDRAM up to 8GB |
Chipset |
Intel® Q45 & ICH10DO or G45 & ICH10(optional, w/o RAID) |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
System Reset Time-out Counter ranges from 1sec (min) to 255sec (min) |
Power Management |
ACPI 1.0 compliant, supports power saving mode with ATX PSU |
VGA Interface |
Intel® integrated extreme GMA 4500 technology |
Video Memory |
Up to 1024MB shared with system memory |
Serial ATA Interface |
6 x Serial ATA II Interface with 300MB/s transfer rate
Support RAID 0, 1, 5, 10 and Intel® Matrix Storage Technology |
Audio Interface |
Integrated ICH10DO with Realtek ALC888 HD Audio. |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Expansion slot |
1x ISA, 2 x PCI, 1 x mini-PCI, one x16 PCI-E & one x4 PCI-E |
Internal I/O Port |
3 x RS232, 1 x LPT, 1 x FDD, 1 x GPIO, 1 x IrDA, 8 x USB,
1 x SMBus, 1 x Front Audio connector, 1 x CDIN |
External I/O Port |
2 x RS232, 1 x RS232/422/485, 2 x LAN, 1 x VGA, 1 x PS/2,
4 x USB, 1 x SPDIF, 1 x Audio |
Power Requirement |
Standard 24-pin ATX power supply ( 20-pin is compatible)
Standard 4-pin 12V power Input connector |
Dimension |
244mm x 244 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
