²úÆ·½éÉÜ
The IPC-5120 is an industrial-grade RoHS compliant wallmount/desktop chassis, built to support microATX motherboards and up to four expansion cards. The IPC-5120 is only 12.1 inches deep and features a brand new ID design. This unit supports front-accessible I/O cabling for easy maintenance and a shorter Mean-Time-to-Repair (MTTR). Also, this unit comes with exciting built-in thermal solutions to reduce processor heat dissipation by up to 115W. The IPC-5120 is really an ideal platform for standalone applications, especially when high performance and convenient maintenance are essential.
