²úÆ·½éÉÜ
Specially designed for factory floor and other harsh industrial environments, the IPC-6606 wallmount IPC chassis is ideal for system integrators or users who require a compact, rugged PC/AT compatible system. The IPC-6606 features a 6-slot passive backplane and a 200 watt power supply. The chassis is only 6.8" wide and can easily be mounted bi-directionally on panels or walls with the supplied brackets.
