Form Factor |
Mini-ITX Motherboard |
Processor |
Intel Core 2 Quad / Core 2 Duo / Celeron Desktop
Package Type: LGA775
Front Side Bus: 800/1066/1333 MHz |
Memory |
2 x DDR3 800/1066MHz DIMM, maximum up to 4GB |
Chipset |
Intel® Q45 Express Chipset & ICH10DO |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
Serial ATA Interface |
Intel ICH10DO built-in 6 x Serial ATA II interface up to 300MB/s
Support RAID 0, 1, 5, 10 and Intel Matrix Storage Technology |
VGA Interface |
Onboard Intel integrated extreme GMA4500 Technology
Optional Secondary VGA connector (LV-67AT) |
Video Memory |
Up to 1024MB shared with system memory |
LVDS Interface |
Optional 18/24-bit dual channel LVDS connector (LV-67AX) |
DVI Interface |
Optional DVI interface (LV-67AD, LV-67AD2) |
Audio Interface |
Intel integrated ICH10DO with Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel 82574L Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extended Interface |
1 x PCI slot, 1 x Mini PCI socket supports Mini PCI Type III A |
Internal I/O Port |
1 x RS232, 1 x Slim FDD, 1 x GPIO, 1 x CDIN, 1 x SMBus,
1 x Audio, 1 x IrDA, 4 x USB2.0 |
External I/O Port |
2 x RS232, 1 x RS232/422/485, 2 x LAN, 1 x VGA, 1 x PS/2
4 x USB2.0, 1 x SPDIF, 1 x Audio |
Power Requirement |
Standard 24-pin ATX power supply and P4 4-pin 12V.
(20-pin is compatible) |
Board Dimension |
170mm x 170 mm (L x W) |
Temperature |
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC |
