Specifications |
Form Factor |
Mini-PCI Type IIIB Interface |
Compression Format |
H.264 |
Video |
Input |
4 channels |
Connector Type |
DB-9 x 1, DB-9 to BNC x 1 |
Display Rate |
4-ch : Total 120 fps (NTSC) / 100 fps (PAL) @ D1 resolution |
Recording Rate |
Audio |
Input |
4 channels |
Connector Type |
DB-9 x 1, DB-9 to RCA x 1 (Optional) |
OS |
Windows XP, Vista (32-bit) |
SDK |
Windows SDK, Network Streaming SDK |
Dimensions |
60 x 45 (mm) |
Support |
User''s manual / Datasheet / Driver |
