Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 20/20RÐ͵¥ºìÍâ»ðÑæÌ½²âÆ÷ ºìÍâ»ðÑæÌ½²âÆ÷
²úÆ·Ãû³Æ£º 20/20RÐ͵¥ºìÍâ»ðÑæÌ½²âÆ÷ ºìÍâ»ðÑæÌ½²âÆ÷
ÐÍ ºÅ£º SharpEyeTM 40/40R
ºìÍâ»ðÑæÌ½²âÆ÷  »ðÑæÌ½²âÆ÷ ×ÏÍâ»ðÑæÌ½²âÆ÷ ·À±¬»ðÑæÌ½²âÆ÷ ÈýÖØºìÍâ»ðÑæÌ½²âÆ÷ ÈýƵºìÍâ»ðÑæÌ½²âÆ÷
SharpEyeTM 40/40Rµ¥ºìÍâ»ðÑæÌ½²âÆ÷
SharpEyeTM 40/40Rµ¥ºìÍâ»ðÑæÌ½²âÆ÷×éºÏº¬Ò»¸öºìÍâ´«¸ÐÆ÷ºÍ¹âѧ¹ýÂËÆ÷,¶ÔCO2 ·¢Éä¹âÆ×(4.4ÄÉÃ×)¾ßÓÐ×î¸ßµÄÁéÃôÐÔ,¶ÔÑô¹âºÍºìÍâ·ÅÓ³»úµÈ»·¾³ºìÍâ¹âÔ´Ëù²úÉúµÄ´íÎ󱨾¯¾ßÓÐÃâÒßÁ¦¡£
SharpEyeTM 40/40R µ¥ºìÍâ»ðÑæÌ½²âÆ÷ÄÜÌṩÓлú²ÄÁÏ(̼Ç⻯ºÏÎï)ȼÉÕ»ðÑæµÄÔçÆÚ±¨¾¯¡£
SharpEyeTM 40/40R µ¥ºìÍâ»ðÑæÌ½²âÆ÷Äܹ»ÔÚ¸ß/µÍÎÂ,¸ßʪ,Õ𶯵È×î¿Á¿ÌµÄ»·¾³Ï¹¤×÷¡£
SharpEyeTM 40/40R µ¥ºìÍâ»ðÑæÌ½²âÆ÷ͨ¹ýÁËIEC61508ÈÏÖ¤ºÍSIL2ÈÏÖ¤¡£
ÌØµã
l          Ãô¸Ð¶È¿Éµ÷
l          Óû§ÉèÖóÌÐò
l          ¸ß´íÎ󱨾¯ÃâÒßÁ¦
l          ×Ô¶¯»òÊÖ¶¯Ð£×¼¹¦ÄÜ (BIT)
l          ±ê×¼4ÏßÁ¬½Ó
l          ¼ÓÈÈ´°¿Ú£¨option£©
l          4-20mA »ò3-4ÏßÊä³ö
l          RS-485 ½Ó¿Ú
l          ×îСƽ¾ù¹ÊÕϼä¸ôʱ¼ä150,000Сʱ
l          3ÄêÖʱ£ÆÚ
l          FM,CSA,ATEX/IECExÈÏÖ¤
l          EN54-10,FM3260,DNV Marine
µäÐÍÓ¦ÓÃ
l          Æû³µ ¨C ÖÆÔì¡¢ÅçÆá·¿
l          »¯Ñ§Æ· ¨C Éú²ú¡¢´¢´æ¡¢ÔËÊä
l          ʯÓÍÌìÈ»Æø ¨C ¿±Ì½¡¢Éú²ú¡¢´¢´æ
l          ÑØº£ ¨C ¾«Á¶³§¡¢³å×°Õ¾¡¢¹ÜµÀ
l          ÓÍÆá ¨C ÖÆÔì
l          ʯ»¯²úÆ· ¨CÉú²ú¡¢´¢´æºÍÔËÊä
l          ÖÆÒ©Òµ
l          ·¢µç ¨C ±ÃÇø¡¢»ú·¿¡¢ÎÞÈËÖ°ÊØÇø
l          Ó¡Ë¢ ¨C ÈܼÁ´¦Àí¡¢Ñ¹Æ½¡¢ºÍ¸ÉÔ﹤ÒÕ
l          ÓͿ⠨C ¸¡¶¯¹Ì¶¨¶¥²ÛÓÍ¿âÇø
l          ²Ö¿â ¨C Ò×ȼƷµÄ´¢´æ
l          ·ÏÆ·´¦Àí³§¨C Ò×ȼƷ¼Ó¹¤¡¢·ÙÉպʹ¢´æ
»ù±¾¼¼Êõ²ÎÊý
¹âÆ×Á¿³Ì
µ¥ºìÍâ¹âÆ×4.4--4.6µm
¼ì²â·¶Î§
(1sq.ft¹ø»ð)
ÆûÓÍ 50ft(15m)
Õý¸ýÍé 50ft(15m)
95%¾Æ¾« 37.5ft(11m)
º½¿ÕÆûÓÍJP4 37.5ft(11m)
úÓÍ 37.5ft(11m)
²ñÓÍ 25ft(7.5m)
·´Ó¦Ê±¼ä
5Ãë(±ê×¼)
¿Éµ÷ÑÓʱ
×î´ó30Ãë
¼à²â·¶Î§
´¹Ö±90o,ˮƽ90o
×Լ칦ÄÜ
ÊÖ¶¯»ò×Ô¶¯×Ô¼ì
ζÈÒªÇó
¹¤×÷ζȣº       £­67oF£¨£­55 oC£©¡«167oF£¨75 oC£©
¹¤×÷ζȣ¨¿ÉÑ¡£©£º£­67oF£¨£­55 oC£©¡«185oF£¨85 oC£©
´¢´æÎ¶ȣº       £­67oF£¨£­55 oC£©¡«185oF£¨85 oC£©
ʪ¶È
95£¥£¨100%·ÇÀäÄýÌõ¼þ϶Ìʱ±©Â¶£©
¼ÓÈȾµÍ·£¨option£©
³ýÎí³ý±ù
µç×Ó¼¼Êõ²ÎÊý
¹¤×÷µçѹ
18£­32VDC
¹¤×÷µçÁ÷
´ý»ú״̬£º100mA£¨×î´ó£© 150mA£¨with heated window£©
±¨¾¯×´Ì¬£º150mA£¨×î´ó£© 200mA£¨with heated window£©
µçÀµ¼¹Ü
2¨w3/4¡å-14NPT »ò 2¨wM25¨w1.5mm ISO
µç·±£»¤
·ûºÏ MIL-STD-1275A±ê×¼
µç´Å¼æÈÝ
EMI/RFI protected CE Marked
Êä³ö
¼ÌµçÊä³ö
±¨¾¯£¬Ê§°ÜºÍ¼æÈÝÐÔÊä³ö£º 5A @30 VDC/250VAC
4£­20mA
ʧ°Ü£¨Fault£©£º
×Ô¼ìʧ°Ü£¨BIT Fault£©£º
Õý³££¨Normall£©£º
ʾ¾¯£¨Warning£©£º
±¨¾¯£¨Alarm£©£º
»·Â·µç×裨Resistance loop£©£º
0
2mA
5mA
10mA
15mA
100-600 Ohm
+1mA
¡À10%       ¡À10%
¡À5%
¡À5%
RS-485
ÅäÖÃÓÐRS-485±ê×¼½Ó¿Ú,¿ÉÓÃÓÚÁ¬½Ó¿ØÖÆÆ÷µÈÉ豸
ÎïÀíÊôÐÔ
ÍâÐγߴç
3.5" x 4.5" x 6.1" (90 x 1114 x 156 mm)
ÖØÁ¿
ÂÁ(Aluminum)£º      2.5Lb (1.2 Kg)
²»Ðâ¸Ö£¨St. St 316L£©£º5.5Lb (2.5 Kg)
ÊÊÓû·¾³
·ûºÏMIL-STD-810C±ê×¼¡£Ó¦ÓÃÓÚ¸ßʪ¡¢¸ßÑΡ¢Õ𶯡¢»úеÕ𶯡¢¸ßκ͵ÍεȻ·¾³¡£
·À»¤ÐÔÄÜ
IP66 and IP67 per En60529
NEMA 250 6P
ÈÏÖ¤
ATEX /Cenelec
EX II 2G, EExd IIB + H2 T5 (70¡ãC)     EX II 2G, EExde IIB + H2 T5 (70¡ãC)
FM / CSA
Class I Div. 1, Groups B, C & D       Class II Div. 1, Groups E, F & G
IEC61508-SIL2,EN54-10(LPCB), FM-3260(FM), DNV Marine Approval
Reliability
IEC61508-SIL2(TVU)
¹«Ë¾Ãû³Æ£º ¼ÎÐËÊдóÕéµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 0573 83990576 / ·Ñ¾­Àí
ÊÖ»ú£º 15888317106
µØ Ö·£º ¼ÎÐËÊгǶ«Â·611ºÅ
ÓÊ ±à£º 314003
Ö÷ Ò³£º http;//www.jxlead.com
  • ºìÍâ·Ö¹â²âÓÍÒÇOIL460ÐÍ
  • ºìÍâ²âÓÍÒÇOIL510ÐÍ
  • Ï£¶û˼DP 500 / DP 520 Pro±ãЯʽ¶µãÒÇ
  • ±ãЯʽ·À±¬ÐÍ¿ÉÈ¼ÆøÌå¼ì²âÒÇ
  • ±ãЯʽ·À±¬ÐͶàÖÖÆøÌå¼ì²âÒÇ
  • T.exÃÀ¹úµÂ¿µÒ»Ñõ»¯Ì¼ÆøÌå¼ì²âÒÇ
  • ±ãЯʽµ¥Ò»ÆøÌå¼ì²âÒÇ
  • ²»Ðâ¸Ö¸´ºÏʽϴÑÛÆ÷LD-30001
  • ÆøÌå¼ì²âÒÇ
  • SAFEÈ¼ÆøÐÐҵרÓÃÒÒÍéÉ«Æ×·ÖÎöÒÇ
