Form Factor |
PICMG 1.3 Full-size CPU card |
CPU |
Intel® Core™ 2 Quad, Core™ 2 Duo, Celeron® processor
Package type : LGA775
FSB : 800/1066/1333MHz |
Memory |
2 x DDR3 800/1066MHz SDRAM up to 4GB |
Chipset |
Intel® Q45 Express & ICH10DO |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 1.0 compliant, supports power saving mode w/ ATX PSU |
VGA Interface |
Intel® integrated extreme GMA 4500 technology |
Video Memory |
Up to 1024 MB shared with system memory |
Serial ATA Interface |
6 x Serial ATA II Interface with 300 MB/s transfer rate
Support RAID 0, 1, 5, 10 and Intel® Matrix Storage Technology |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Expansion Interface |
Support one x16 PCIe, one x4 PCIe or four x1 PCIe
Support four PCI bus master, four USB2.0 interface |
External I/O Port |
DB15 VGA port, RJ45 LAN port, PS/2 Keyboard/Mouse port |
Internal I/O Port |
5 x RS232, 1 x RS232/422/485, 1 x LPT, 1 x FDD, 1 x GPIO
1 x IrDA, 8 x USB2.0, 1 x SMBus, 1 x Front Audio, 1 x CDIN |
Power Requirement |
+5V, +12V & 5VSB |
Board Dimension |
338mm x 126 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
