Form Factor |
3.5" Miniboard (146 x 101 mm) |
CPU |
Intel® AtomTM Z510P processor 1.1GHz
Package type : 437-pin FCBGA8 with an IHS
Front Side Bus : 400MHz |
Memory |
1 x 200-pin DDR2-400 SO-DIMM SDRAM up to 2GB
Support Non-ECC, unbuffered memory only |
Chipset |
Intel® SCH US15WP |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min(sec) ~ 255min(sec) |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
Integrated Graphics |
Intel® integrated extreme GMA 500(Graphic Media Accelerator) Technology |
Video Memory |
Up to 256MB shared with system memory |
VGA Interface |
Chrontel CH7317A with DSUB15 connector ( optional) |
LVDS Interface |
Chipset Integrated 18/24-bit single channel LVDS
Chrontel CH7308 for 18/24-bit dual channel (optional) |
DVI Interface |
Chrontel CH7307C with HDMI connector ( optional) |
Solid State Disk |
IDE supports 44-pin DiskOnModule +5V power supply
1 x CompactFlash Type-II, 1 x SD 1.1 socket |
Audio Interface |
Intel® SCH integrated with Realtek ALC888 HD Codec |
LAN Interface |
1 x Intel® 82574L Gigabit Ethernet controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Expansion Interface |
1 x PCIe mini card socket |
Internal I/O Port |
1 x IrDA, 1 x GPIO, 1 x Audio, 1 x CDIN, 4 x USB2.0, 1 x SMBus,
1 x LVDS, 1 x LCD Inverter, 1 x RS232/422/485, 1 x LPC |
External I/O Port |
1 x COM, 1 x VGA/DVI, 1 x RJ45, 2 x USB2.0, 1 x PS2 |
Power Requirement |
9~24V full range DC input |
Board Dimension |
146mm x 101mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
