| ¶©»õºÅ |
²ÎÊý |
¼Û¸ñ |
| 6ES79720AA000XA0 |
SIMATIC S7, RS485 REPEATERZUR VERBINDUNG VON PROFIBUS/MPIBUSSYSTEMEN MIT MAX. 31 TEILN.MAX. 12 MBIT/S, SCHUTZART IP20SIMATIC S7, RS485 REPEATER FORTHE CONNECTION OF PROFIBUS/MPIBUS SYSTEMS WITH MAX. 31 NODES;MAX. 12 MBIT/S, IP20 |
7,479.40 |
| 6ES79720AA010XA0 |
SIMATIC DP, RS485 REPEATERZUR VERBINDUNG VON PROFIBUS/MPIBUSSYSTEMEN MIT MAX. 31 TEILN.MAX. BAUDRATE 12 MBIT/S,SCHUTZART IP20SIMATIC DP, RS485 REPEATER FORTHE CONNECTION OF PROFIBUS/MPIBUS SYSTEMS WITH MAX. 31 NODES;MAX. 12 MBIT/S, DEGREE OF PRO-TECTION I |
3,288.41 |
| 6ES79720AB000XA0 |
SIMATIC S7, DIAGNOSE-REPEATERFUER PROFIBUS-DP, ZUR ONLINE-DIAGNOSE DER PROFIBUS-LEITUNG,DP-NORM-SLAVE BIS 12 MBIT/S,SCHUTZART IP20, FAST-CONNECT-SIMATIC S7, DIAGNOSIS-REPEATERFOR PROFIBUS-DP, FOR ONLINEPROFIBUS CABLE DIAGNOSISDP-STAND-SLAVE UP TO 12 MBIT/ |
15,843.84 |
| 6ES79720AB010XA0 |
SIMATIC S7, DIAGNOSE-REPEATERFUER PROFIBUS-DP, ZUR ONLINE-DIAGNOSE DER PROFIBUS-LEITUNG,DP-NORM-SLAVE BIS 12 MBIT/S,SCHUTZART IP20, FAST-CONNECT-SIMATIC S7, DIAGNOSIS-REPEATERFOR PROFIBUS DP, FOR ONLINEPROFIBUS CABLE DIAGNOSTICS,DP-STANDARD SLAVE TO 12MBI |
7,743.74 |
| 6ES79720AC800XA0 |
SIMATIC DP, DEZENTR. PERIPHERIEFELDGERAETEANBINDUNGRS485-IS KOPPLER,FELDBUSKOPPLER ZWISCHENPROFIBUS DP UND RS485-IS,SIMATIC DP, DISTRIBUTED I/OFIELD DEVICE LINKRS485-IS COUPLER,FIELD BUS COUPLER BETWEENPROFIBUS DP AND RS485-IS, |
8,221.02 |
| 6ES79720BA120XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/S90 GRAD KABELABGANG,(B X H X T): 15,8 X 54 X 34 MMABSCHLUSSWIDERSTAND MITSIMATIC DP, BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/S90 DEGREE ANGLE OUTGOING CABLE,(W X H X D): 15,8 X 54 X 34 MMTERMINAT. RES |
402.7 |
| 6ES79720BA300XA0 |
SIMATIC DP, BUSANSCHLUSS-STECKER F. PROFIBUS M.SAEGEMKABELABGANG, MAX.1,5 MBAUD,(B X H X T): 15 X 58 X 34 MMSCHNEIDKLEMMEN, O.BUSANSCHLUSS-SIMATIC DP, BUS CONNECTOR FORPROFIBUS, WITH TILTED OUTGOINGCABLE,INSUL.PIERCING CONN.DEV.,(W X H X D) 15 X 58 X 3 |
235.06 |
| 6ES79720BA410XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/SMIT SAEGEM KABELABGANG,(B X H X T): 16 X 54 X 34 MMABSCHLUSSWIDERSTAND MITSIMATIC DP,BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/SWITH TILTED OUTGOING CABLE,(W X H X D): 16 X 54 X 34 MMTERMINAT. RESIST |
402.7 |
| 6ES79720BA500XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/S90 GRAD KABELABGANG,(B X H X T): 16 X 72,7 X 34 MMSCHNEIDKLEMMTECHNIKSIMATIC DP,BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/S90 DEGREE ANGLE OUTGOING CABLE,(WX H X D): 16 X 72,7 X 34 MMIPCD TECHOLOGY FAST |
402.7 |
| 6ES79720BA510XA0 |
SIMATIC DP,BUS CONNECTOR FOR PROFIBUS UP TO 12 MBIT/S 90 DEGREE ANGLE OUTGOING CABLE, 15,8 X 59 X 35,6 MM (WXHXD), IPCD TECHOLOGY FAST CONNECT, WITHOUT PG SOCKET |
402.7 |
| 6ES79720BA520XA0 |
SIMATIC DP,BUS CONNECTOR FOR |
402.05 |
| PROFIBUS UP TO 12 MBIT/S |
| 90 DEGREE ANGLE OUTGOING CABLE, |
| 15,8 X 59 X 35,6 MM (WXHXD), |
| IPCD TECHOLOGY FAST CONNECT, |
| WITHOUT PG SOCKET |
| 6ES79720BA600XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/S35 GRAD KABELABGANG,(B X H X T): 16 X 72,7 X 34 MMSCHNEIDKLEMMTECHNIKSIMATIC DP,BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/S35 DEGREE ANGLE OUTGOING CABLE,(WX H X D): 16 X 72.7 X 34 MMIPCD TECHOLOGY FAST |
402.7 |
| 6ES79720BB120XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/S90 GRAD KABELABGANG,(B X H X T): 15,8 X 54 X 34 MMABSCHLUSSWIDERSTAND MITSIMATIC DP, BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/S90 DEGREE ANGLE OUTGOING CABLE,(W X H X D): 15.8 X 54 X 34 MMTERMINAT. RES |
536.93 |
| 6ES79720BB410XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/SMIT SAEGEM KABELABGANG,(B X H X T): 16 X 54 X 34 MMABSCHLUSSWIDERSTAND MITSIMATIC DP, BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/SWITH TILTED OUTGOING CABLE,(W X H X D): 16 X 54 X 34 MMTERMINAT. RESIS |
536.93 |
| 6ES79720BB500XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/S90 GRAD KABELABGANG,(B X H X T): 16 X 72,7 X 34 MMSCHNEIDKLEMMTECHNIKSIMATIC DP, BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/S90 DEGREE ANGLE OUTGOING CABLE,(WX H X D): 16 X 72,7 X 34 MMIPCD TECHOLOGY FAS |
536.93 |
| 6ES79720BB510XA0 |
SIMATIC DP,BUS CONNECTOR FOR PROFIBUS UP TO 12 MBIT/S 90 DEGREE ANGLE OUTGOING CABLE, 15,8 X 59 X 35,6 MM (WXHXD), IPCD TECHOLOGY FAST CONNECT, WITH PG SOCKET |
536.93 |
| 6ES79720BB520XA0 |
535.9 |
| WITH PG SOCKET |
| 6ES79720BB600XA0 |
SIMATIC DP, ANSCHLUSSSTECKERFUER PROFIBUS BIS 12 MBIT/S35 GRAD KABELABGANG,(B X H X T): 16 X 72,7 X 34 MMSCHNEIDKLEMMTECHNIKSIMATIC DP, BUS CONNECTOR FORPROFIBUS UP TO 12 MBIT/S35 DEGREE ANGLE OUTGOING CABLE,(WX H X D): 16 X 72.7 X 34 MMIPCD TECHOLOGY FAS |
536.93 |
| 6ES79720CA110XA0 |
SIMATIC S7, HMI ADAPTER V5ZUM ANSCHLUSS VON FREMD-B+B-GERAETEN AN S7-300/-400MIT RS 232/RS 485-UMSETZUNGSIMATIC S7, HMI ADAPTER V5FOR CONNECTION OF NON-SIEMENSHMI SYSTEMS TO S7-300/-400WITH RS 232/RS 485 CONVERSION |
5,592.63 |
| 6ES79720CA220XA0 |
SIMATIC S7, PC ADAPTER V5ZUM ANSCHLUSS AN S7-300/-400,C7, M7; FUER PC OHNE FREIENSTECKPLATZ; UMSETZUNG RS232(19,2/38,4 KBIT/S) AUF RS485SIMATIC S7, PC ADAPTER V5FOR CONNECTION OF S7-300/400,C7, M7; FOR PC W/O FREE SLOT;FOR CONVERSION OF RS232(19.2/38.4 KB |
6,652.98 |
| Î÷ÃÅ×ÓRS232/RS485ÊÊÅäÆ÷ |
SIMATIC S7, PC ADAPTER V5.1ZUM ANSCHLUSS AN S7-300/-400,C7, M7; ZUR UMSETZUNG RS232AUF RS485; OHNE RS232-KABELSIMATIC S7, PC ADAPTER V5.1FOR CONNECTION OF S7-300/400,C7, M7; FOR CONVERSION OF RS232TO RS485; W/O RS232 CABLE |
5,272.18 |
| 6ES79720CA230XA0 |
| 6ES79720CA320XA0 |
SIMATIC S7, TS ADAPTER V5ZUM ANSCHLUSS VON MODEMAN S7-300/-400, M7, C7MIT RS 232/RS 485-UMSETZUNGLIEFERUMFANG OHNE RS232-KABELSIMATIC S7, TS ADAPTER V5FOR CONNECTION OF A MODEMTO S7-300/-S7-400, M7, C7WITH RS 232/RS 485 CONVERSIONPRODUCT PACKAGE W/O RS232 |
7,845.50 |
| 6ES79720CA330XA0 |
SIMATIC S7, TS ADAPTER V5.1FUER SIMATIC TELESERVICEFUER S7-300/-400, M7, C7MIT RS 232/RS 485-UMSETZUNGLIEFERUMFANG OHNE RS232-KABELSIMATIC S7, TS ADAPTER V5.1FOR SIMATIC TELESERVICEFOR S7-300/-S7-400, M7, C7WITH RS 232/RS 485 CONVERSIONPRODUCT PACKAGE W/O |
7,578.75 |
| 6ES79720CA340XA0 |
SIMATIC S7, TS-ADAPTER 5.2FUER SIMATIC TELESERVICEFUER S7-300/-400, M7, C7MIT RS 232/RS 485-UMSETZUNGLIEFERUMFANG OHNE RS232-KABELSIMATIC S7, TS ADAPTER 5.2FOR SIMATIC TELESERVICEFOR S7-399/-400, M7, C7WITH RS 232/RS 485 CONVERSIONPRODUCT PACKAGE W/O RS23 |
6,951.11 |
| Î÷ÃÅ×ÓS7-300/400±à³ÌµçÀÂPC ADAPTER USB |
SIMATIC S7, PC ADAPTER USBZ. ANSCHLUSS AN S7-200/300/400,C7; MIT USB-KABEL (5M)EINSETZBAR UNTER WIN 2000/ XPSIMATIC S7, PC ADAPTER USBF. CONNECTION OF S7-200/300/400C7; WITH USB-CABLE (5M)CAN BE USED UNDER WIN 2000/XP |
4,410.68 |
| 6ES79720CB200XA0 |
| 6ES79720CB350XA0 |
SIMATIC S7, TS-ADAPTER IIFUER SIMATIC TELESERVICERS232 UND INTEGR. ANALOG MODEMANSCHLUSS AN MPI/DPSTROMVERSORG. MPI ODER EXT. 24VSIMATIC S7, TS ADAPTER IIFOR SIMATIC TELESERVICERS232 AND INTEGR. ANALOG MODEMCONNECTION ON MPI/DPPOWER SUPPL. MPI OR EXT. 2 |
7,927.70 |
| 6ES79720CC350XA0 |
SIMATIC S7, TS-ADAPTER II ISDNFUER SIMATIC TELESERVICERS232 UND INTEGR. ISDN MODEMANSCHLUSS AN MPI/DPSTROMVERSORG. MPI ODER EXT. 24VSIMATIC S7, TS ADAPTER II ISDNFOR SIMATIC TELESERVICERS232 AND INTEGR. ISDN MODEMCONNECTION ON MPI/DPPOWER SUPPL. MPI OR |
8,936.68 |
| 6ES79720DA000AA0 |
SIMATIC DP, RS485 ABSCHLUSS-WIDERSTAND ZUR TERMINIERUNG VONPROFIBUS-/MPI-NETZENSIMATIC DP, RS485 RESISTORFOR TERMINATINGPROFIBUS-/MPI-NETWORKS |
805.4 |
| 6ES79720DA300XA0 |
SIMATIC DP, BUSANSCHLUSSSTECKERFUER PROFIBUS M.SAEGEMKABELABGANG, MAX.1,5 MBAUD,(B X H X T): 15 X 58 X 34 MMSCHNEIDKLEMMEN, MIT PASSIVEMSIMATIC DP, BUS CONNECTOR FORPROFIBUS, WITH TILTED OUTGOINGCABLE,INSUL.PIERCING CONN.DEV.,(W X H X D) 15 X 58 X 34 M |
676.79 |
| 6ES79720DA600XA0 |
SIMATIC DP, BUSANSCHLUSSSTECKERFUER PROFIBUS M.SAEGEMKABELABGANG, MAX.1,5 MBAUD,(B X H X T): 16 X 72,7 X 34 MMSCHNEIDKLEMMEN, MIT AKTIVEMSIMATIC DP, BUS CONNECTOR FORPROFIBUS, WITH TILTED OUTGOINGCABLE,INSUL.PIERCING CONN.DEV.,(W X H X D) 16 X 72,7 X 3 |
489.2 |
| 6ES79720ED000XA0 |
SIMATIC S7, TS-ADAPTER IE ISDNFOR SIMATIC TELESERVICERS232 AND INTEGR. ISDN MODEMCONNECTION ON ETHERNETPOWER SUPPLLY EXT. 24V |
10,378.08 |
| 6ES79720EM000XA0 |
SIMATIC S7, TS-ADAPTER IE MODEMFOR SIMATIC TELESERVICERS232 AND INTEGR. ANALOG MODEMCONNECTION ON ETHERNETPOWER SUPPLLY EXT. 24V |
9,369.10 |
| 6ES79724AA000XA0 |
SIMATIC DP, POWER RAIL BOOSTERSIGNALVERSTAERKER FUER DIEUEBERTRAGUNG DES PROFIBUS-DPUEBER SCHLEIFLEITUNGENMAX. 500 KBIT/SSIMATIC DP, POWER RAIL BOOSTERSIGNAL AMPLIFIER FORTRANSMITTING THE PROTOCOL OFPROFIBUS-DP USINGCOLLECTOR WIRES, MAX 500 KBIT/S |
14,889.39 |
| 6ES79724AA010XA0 |
14,889.39 |
| 6ES79724AA020XA0 |
7,755.68 |
| 6ES79724AA500XA0 |
SIMATIC DP,PRB SEGMENT CONTROLLER,AUTOMATISCHER UMSCHALTERZWISCHEN PRB-SEGMENTENSIMATIC DP,PRB SEGMENT CONTROLLER,AUTOMATIC CHANGE-OVER SWITCHBETWEEN PRB SEGMENTS |
6,490.90 |
