| Application System |
1U Form Factor Active Solution |
| CPU Type |
Intel Pentium 4 (Prescott, Cedar Mill) |
| Intel Pentium D (Smithfield, Presler) |
| Intel Core 2 Duo (Conroe) |
| Intel Core 2 Quad (Kentsfield) |
| Supported CPU Frequency |
2.8 ~ 3.4 GHz up for Pentium 4; FSB 800 MHz up |
| 2.8 ~ 3.4 GHz up for Pentium D; FSB 800 MHz up |
| 1 .8 ~ 2.66 GHz up for Core 2 Duo; FSB 800 MHz up |
| 2.4 GHz up for Core 2 Quad; FSB 1066 MHz up |
| Socket Type |
LGA 775 |
| Heat Sink |
Copper Base + Copper Stacked Fin |
| Cooler Dimension |
93 x 93 x 27.5 mm |
| Fastener |
Screw + Spring |
| Interface Material |
Shin Etsu 7783 |
| Fan Dimension |
70 x 70 x 13 mm |
| Fan Speed |
5,500 rpm |
| Fan Airflow |
8.9 CFM |
| Fan Bearing Type |
Dual Ball Bearing |
| Voltage Rating |
12 V |
| Noise Level |
40 dBA |
| Connector |
4 Pins with PWM function |
| Thermal Resistance |
For Prescott: 0.45 ¡ãC/W |
| For Cedar Mill: 0.45 ¡ãC/W |
| For Smithfield: 0.30 ¡ãC/W |
| For Presler: 0.30 ¡ãC/W |
