²úÆ·Ãû³Æ£º
DSCA45-01
ÐÍ ºÅ£º
DSCA45-01
| Input Range: |
0 to 500 Hz |
| Output Range: |
0 to +10 V |
| Zero Crossing Hysterisis: |
40mV |
| Mechanical Format: |
DIN rail |
| Isolation Voltage: |
1500 Vrms |
| Isolation Type: |
Transformer 3-way |
| Accuracy: |
¡À0.05% Span |
| Supply Voltage: |
19 to 29 Vdc (+24V Nom) |
| Input Voltage Withstand: |
240 Vrms |
| Gain/Offset Adjust: |
¡À5% |
| External I-to-V Resistor: |
N/A |
| Output Control: |
Always enabled |
| Output Resistance: |
<1 Ohm |
| Dimensions: |
2.95 x 0.89 x 4.13 inches |
| Interface: |
8 Pos terminal block |
| Customization: |
yes |
