Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú SCM5B34-01
²úÆ·Ãû³Æ£º SCM5B34-01
ÐÍ ºÅ£º SCM5B34-01
Input Configuration: 2 & 3 Wire
RTD Type: 100 Ohm Platinum
Input Range: -100 to 100 (¡ãC)
Output Range: 0 to +5 V
Mechanical Format: Modular plug-in-board
Isolation Voltage: 1500 Vrms
Isolation Type: Transformer 3-way
Accuracy: ¡À0.12¡ãC
Supply Voltage: +5VDC ¡À5%
Input Voltage Withstand: 240 Vrms
Gain/Offset Adjust: N/A
Module Bandwidth: 4 Hz
NMR (60 Hz) Rejection: 95dB at 60Hz, 90dB at 50Hz
External I-to-V Resistor: N/A
Output Control: Enable/Disable
Output Resistance: 50 Ohms
Dimensions: 2.28 x 2.26 x 0.60 inches
Interface: 14 pin
Customization: yes
¹«Ë¾Ãû³Æ£º ÉϺ£¹Èάµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 59185688 / Æî½¨ÇÙ
ÊÖ»ú£º 18921449352
µØ Ö·£º ÉϺ£Êмζ¨Çø»ãÉÆÂ·685ºÅ4ºÅÂ¥3Â¥
ÓÊ ±à£º 200093
Ö÷ Ò³£º http://www.guwei.com.cn
  • »ôÄáΤ¶û1900ÊÖ³ÖʽÌõÂëɨÃèÆ÷
  • »ôÄáΤ¶û1902¶þάӰÏñÌõÂëɨÃèÆ÷
  • ÎÞÖ½¼Ç¼ÒÇAMS2750
  • ÎÞÖ½¼Ç¼ÒÇAMS2750
  • ÎÞÖ½¼Ç¼ÒÇAMS2750
  • Honeywell ζȿØÖÆÆ÷ DC1040CR-701-000-E
  • Honeywell/»ôÄáΤ¶û UDC3500ζȿØÖÆÆ÷
  • ÃÀ¹ú»ôÄáΤ¶ûHoneywell HC900/SIL2
  • HoneywellUDC2500-C0-0A00-200-000000-00-0 ÎÂ¿ØÆ÷
  • SensorLexTM8B¸ôÀëÄ£ÄâÐźŵ÷½ÚÆ÷
