²úÆ·Ãû³Æ£º
8B49-01
ÐÍ ºÅ£º
8B49-01
| Input Range: |
0 to +5 V |
| Output Range: |
-5 to +5 V |
| Mechanical Format: |
Modular plug-in-board |
| Isolation Voltage: |
1500 Vrms |
| Isolation Type: |
Transformer/Optical |
| Accuracy: |
¡À0.05% span (0-5mA load) |
| Supply Voltage: |
+5VDC ¡À5% |
| Output Voltage Withstand: |
40 Vrms |
| Gain/Offset Adjust: |
N/A |
| Module Bandwidth: |
1 kHz |
| NMR (60 Hz) Rejection: |
60dB per decade above 1kHz |
| External I-to-V Resistor: |
N/A |
| Output Control: |
N/A |
| Output Resistance: |
N/A |
| Dimensions: |
1.11 x 1.65 x 0.40 inches |
| Interface: |
7 pin |
| Customization: |
yes |
