Ò»¡¢HS5660C¾«ÃÜÔëÉùƵÆ×·ÖÎöÒǸÅÊö |
HS5660CÐ;«ÃÜÔëÉùƵÆ×·ÖÎöÒÇÊÇÒ»ÖÖÖÇÄÜ»¯ÔëÉù²âÁ¿ÒÇÆ÷£¬ÐÔÄÜ·ûºÏIEC61672±ê×¼¶Ô1¼¶Éù¼¶¼ÆºÍGB3785±ê×¼¶Ô1ÐÍÉù¼¶¼ÆµÄÒªÇó£¬Í¬Ê±Ò²·ûºÏIEC1260ºÍGB/T3241±ê×¼¶Ô±¶Æµ³ÌÂ˲¨Æ÷µÄÒªÇó¡£·ÖÎöÒDzÉÓÃÊý×ּ첨¼¼Êõ£¬Îȶ¨ÐԺͿɿ¿ÐÔ´ó´óÌá¸ß£¬ÊÊÓÃÓÚ¸÷ÖÖ¹¤Òµ»·¾³ÔëÉù²âÁ¿ÓÈÆäÊÊÓÃÓÚ¶ÔÔëÉù½øÐÐÆµÆ×·ÖÎö¡£±¾ÒÇÆ÷²âÁ¿·½±ã¿É¿¿£¬¿É¹ã·ºÓÃÓÚ»·¾³¼à²â¡¢ÎÀÉú·ÀÒß¡¢ÀͶ¯±£»¤¡¢Ñ§Ð£½Ìѧ¡¢¿ÆÑеȲ¿ÃŽøÐи÷ÖÖÔëÉùµÄ²âÁ¿¡£ |
¶þ¡¢HS5660C¾«ÃÜÔëÉùƵÆ×·ÖÎöÒÇÖ÷Òª¼¼Êõ²ÎÊý¼°ÐÔÄÜ |
´« Éù Æ÷ |
§¶12.7mm£¨1/2¡å£©Ô¤¼«»¯²âÊÔµçÈÝ´«ÉùÆ÷ |
ƵÂÊ·¶Î§ |
10Hz-20kHz |
ƵÂʼÆÈ¨ |
A¼ÆÈ¨¡¢C¼ÆÈ¨¡¢Lin(ÏßÐÔ) |
²âÁ¿·¶Î§ |
25dB-130dB£¨A£©¡¢30dB-130dB£¨C£©¡¢40dB-130dB£¨Lin£© |
Á¿³Ì¿ØÖÆ |
ÊÖ¶¯Ñ¡Ôñ£¬·ÖÈýµµ£¬ÏßÐÔ·¶Î§70dB¡£ |
Á¿³Ì·¶Î§ |
L£º23dB -90dB |
M£º40dB -110dB |
H£º70dB -130dB |
ÒÇÆ÷¾«¶È |
·ûºÏIEC61672 1¼¶»òGB3785 1ÐÍ |
ʱ¼ä¼ÆÈ¨ |
¿ì£¨F£©¡¢Âý£¨S£© |
¶¨Ê±²âÁ¿ |
Lp¡¢Leq¡¢Lae¡¢L5¡¢L10¡¢L50¡¢L90¡¢L95¡¢Lmax¡¢Lmin¡¢SD¡¢Ld¡¢Ln¡¢LdnµÈ |
ʱ¼äÉ趨 |
10s¡¢1min¡¢5min¡¢10min¡¢15min¡¢20min¡¢1h¡¢4h¡¢ 8h¡¢Õûʱ24h |
²ÉÑùʱ¼ä |
31ms |
ÂË ²¨ Æ÷ |
ÄÚÖÃʽ1/1±¶Æµ³Ì |
ÖÐÐÄÆµÂÊ£º31.5Hz¡¢63Hz¡¢125Hz¡¢250Hz¡¢500Hz¡¢1kHz¡¢2kHz¡¢4kHz¡¢8kHz |
²âÁ¿ÏÔʾ |
´óÆÁÄ»¶¯Ì¬Òº¾§ÏÔʾÆ÷£¬Ë²Ê±Éù¼¶ÏÔʾ¾ßÓÐÄ£Äâµç±í¹¦ÄÜ |
Êý¾Ý´¢´æ |
500×éµ¥×éÊý¾Ý¡¢4×éÕûʱÊý¾Ý¡¢50×éÂ˲¨Æ÷×Ô¶¯²âÁ¿Êý¾Ý |
Êä³ö½Ó¿Ú |
ACÊä³ö½Ó¿Ú£ºÌṩ½»Á÷µçѹÐźſÉÓÃÓÚÍâ½Ó·ÖÎö |
RS-232½Ó¿Ú£ºÓÃÓÚ΢ÐÍ´òÓ¡»ú½øÐÐÏÖ³¡´òÓ¡»òʺóͨ¹ý¼ÆËã»úͨѶ´òÓ¡ |
У ׼ |
HS6020Éù¼¶Ð£×¼Æ÷£¬1000Hz 94dB |
µç Ô´ |
5½Ú5ºÅ¼îÐÔµç³Ø£¬¿ÉÁ¬Ðø¹¤×÷24Сʱ£¬¿ÉÍâ½ÓµçÔ´DC9V |
ÍâÐγߴç |
l¡Áb¡Áh(mm):307¡Á80¡Á30£¬ÖÊÁ¿£º386g£¨Á¬µç³Ø£© |
Èý¡¢HS5660C¾«ÃÜÔëÉùƵÆ×·ÖÎöÒÇÆäËü£º |
1¡¢»ù±¾ÅäÖãºÖ÷»ú¡¢´òÓ¡»ú¡¢·çÕÖ¡¢ÖÓ±íÆð×Ó¡¢ÂÁºÏ½ðÏä¡£ |
2¡¢Ñ¡¹º¸½¼þ£ºÐ£×¼Æ÷¡¢ÑÓÉìµçÀ£¨5m/10m/15m£©¡¢Èý½Å¼Ü¼°ÅäÌ×´òÓ¡»ú¡£ |
