·ûºÏEPS12V 2.92°æ±¾,¶î¶¨700W(×î´ó860W) ¿íµçѹÊäÈ루100-240Vac£© ¸ßЧÂÊ &# µÍÁ°²¨ÔÓѶÊä³ö & ¸÷×éÊä³ö¾ß±¸¹ýµçѹ±£»¤ • ¸÷×éÊä³öµçѹ¾ß±¸¶Ì·µçÁ÷±£»¤ • ÄÚÖÃ14CMÉ¢ÈÈ·çÉÈ • 100%¸ßѹ²âÊÔ • 100%¸ßÎÂÀÏ»¯²âÊÔ(50¡æ) • Ö÷¶¯Ê½PFC • ÊÙÃüÖÜÆÚ:¡Ý100KHСʱÒÔÉÏ
Ïß²ÄÓ¦Óà : | |
20+4pin Ö÷½ÓÍ· |
4+4pin £«12V CPU |
4pinÍâÉè É豸½ÓÍ· |
4pin ÈíÇý É豸½ÓÍ· |
5pinSATA É豸½ÓÍ· |
6-pin PCI Express ½ÓÍ· | |
ÊäÈë¹æ¸ñ : | |
• ÊäÈëµçѹ£º100-240V • ƵÂÊ£º47-63Hz • ÊäÈëµçÁ÷£º10-5A @100-240Vac 47Hz-63Hz
Êä³ö¹æ¸ñ : | |
• ×î´ó¹¦ÂÊ:700W • ÑÕÉ«: Black • É¢ÈÈϵͳ: SPEED: 2200RMP(+/-10%) DIMENSION:158*150*86mm TEMP.AUTO ONTROL: 800rpm at 41.7cfm~2200rpm at 95.5cfm 14CM fan • ÔëÒô: 22dB at 1800rpm • P.GÐźÅ: 100-500ms • ±£³Öʱ¼ä: 17ms(min) • ЧÂÊ: 80% | |
Êä³ö : | |
Output Voltage |
Min. load |
Max. load |
Load Reg. |
Ripple & Noise |
-12V |
0.0A |
0.8A |
¡À10% |
120mV P-P |
+3.3V |
1.5A |
28.0A |
¡À5% |
50mV P-P |
+5V |
1.0A |
30.0A |
¡À5% |
50mV P-P |
+5Vsb |
0.1A |
3.0A |
¡À5% |
50mV P-P |
+12V1 |
0.8A |
16.0A |
¡À5% |
120mV P-P |
+12V2 |
0.8A |
16.0A |
¡À5% |
120mV P-P |
+12V3 |
0.5A |
18.0A |
¡À5% |
120mV P-P |
+12V4 |
1.0A |
18.0A |
¡À5% |
120mV P-P |
£®+3.3V & +5V total output shall not exceed 170W. £®Maximum combined current for the 12V outputs shall be 56A £®Peak current for the combined 12V outputs shall be 62A * Detailed specifications and drawings provided upon request.
