Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Elcometer110ÆøÑ¹Ð͸½×ÅÁ¦²âÁ¿ÒÇ
²úÆ·Ãû³Æ£º Elcometer110ÆøÑ¹Ð͸½×ÅÁ¦²âÁ¿ÒÇ
ÐÍ ºÅ£º Elcometer110
Elcometer110ÆøÑ¹Ð͸½×ÅÁ¦²âÁ¿ÒÇÏêϸÐÅÏ¢
Elcometer110ÊÇÒ»ÖÖЯ´ø·½±ãµÄÆøÑ¹Ð͸½×ÅÁ¦²âÁ¿ÒÇ£¬ËùÓõÄѹËõÆøÌåÀ´Ô´ÓÚ¹Þ×°»òѹËõ¿ÕÆø.
ÓÉÓÚËùÓõÄÁ¦ÊǿɿØÖƵģ¬¹Ê²âÊԵĽá¹ûÖµÖØ¸´ÐԸߡ£ÎªÓû§ÌṩÀíÏëµÄ²âÊÔ¹¤¾ßÒ×Óò¢ÓµÓÐ1%µÄ¾«È·¶È*.
ÓÐһϵÁÐÄÜ»¥»»µÄ»îÈû£¬µ±Á¬½ÓÉÏÍâÀ´Ñ¹ËõÆø»ò¹Þ×°¶þÑõ»¯Ì¼Ê±, Óû§¿É²âÊԸߴï70MPa / 10000PSI
*¾«È·¶ÈÊÓÔ²ÐζÍÄ£µÄλÖöø¶¨--¡À1%Ϊ¹¤³§ÊµÑé²â¶¨
ÆøÌ幩¸ø ÄÚ²¿´æ´¢¹Þ¿Éͨ¹ýÍâÀ´ÆøÌå¹Þ»ò¹ÜµÀ³äÆø
µçÔ´ 9V (PP3, 6F22) »òÕßÓÿÉÑ¡µÄ110 - 240V AC ÊÊÅäÆ÷
³ß´ç 100 x 255 x 255mm (4 x 10.5 x 10.5")
À­°ôÖ±¾¶ 12.7mm (0.5")
ÖØÁ¿ ²»º¬¹¤¾ßÏä 2.7kg (5.9°õ)
ÆøÑ¹ÊäËÍËÙ¶È ¿Éµ÷ÖÁÿÃë150 PSI
Packing List
Elcometer 110 PATTI® Adhesion Tester, pull stubs (x25), cut-off ring (x25), talcum powder, epoxy adhesive, carry case and operating instructions.
Pistons are not supplied as standard and must be ordered separately.
ÐͺŠÃû³Æ
Áã¼þºÅ
Elcometer 110 Elcometer110ÆøÑ¹Ð͸½×ÅÁ¦²âÁ¿ÒÇ
F110----A
»îÈû F1: 0 - 3.4MPa / 0 - 500psi
T11013400
F2: 0 - 6.9MPa / 0 - 1000psi
T11013401
F4: 0 - 13.8MPa / 0 - 2000psi
T11013402
F8: 0 - 27.6MPa / 0 - 4000psi
T11013403
F16: 0 - 55.2MPa 0 - 8000psi
T11013404
F20: 0 - 70MPa / 0 - 10000psi
T11013405
¸½¼þ À­°ô£¨25¸ö/°ü£©, 12.7mm (0.5")Ö±¾¶
T11013388
Çл·£¨25¸ö/°ü£©, 12.7mm (0.5")Ö±¾¶
T11013389
À­°ôÇиîÆ÷, 12.7mm (0.5")Ö±¾¶
T11014019
Á¬½Ó¹ÜÑÓÉì¼þ, 2m (78")
T11013261
ѹËõÆø¹©Ó¦¹ÜÈ«²¿¼þ
T11013455
»·Ñõð¤ºÏ¼Á
T99912906
µçÔ´ÊÊÅäÆ÷, UK 240V
T1109987-
µçÔ´ÊÊÅäÆ÷, EUR 220V
T1109988-
µçÔ´ÊÊÅäÆ÷, US 110V
T1109989-
¶þÑõ»¯Ì¼µ¯¹Ì¶¨Æ÷
T11019559
·ûºÏÏÂÁбê×¼
ASTM D 4541 AS/NZS 1580.408.5
ISO 16276-1
¹«Ë¾Ãû³Æ£º ÉòÑôÊа®¶ûÆÕÒÇÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 024 23180978 / ½ªÓÀÁÁ
ÊÖ»ú£º 13840333978
µØ Ö·£º ÇàÄê´ó½Ö386ºÅ»ªÑô´óÏÃ0785ÊÒ
ÓÊ ±à£º 110004
Ö÷ Ò³£º http://www.ellpo.com
  • ÃÀ¹úÀ×Ì©ST60+ºìÍâ²âÎÂÒÇ
  • Raynger RAYST80XBAPºìÍâÏß²âÎÂÒÇ
  • RAYTEK ST80XBºìÍâ²âÎÂÒÇ
  • AR892ºìÍâ²âÎÂÒÇ
  • AR882ºìÍâÏß²âÎÂÒÇ
  • AR872AºìÍâ²âÎÂÒÇ
  • F65ºìÍâ²âÎÂÒÇ
  • 3ILRL3UºìÍâ²âÎÂÒÇ
  • HG2508²âÕñ²âÎÂÒÇ
  • 3ILTCL3UÔ¶ºìÍâ²âÎÂÒÇ
