ʾ²¨Æ÷ |
ÐͺŠ|
PicoScope 4224 |
PicoScope 4424 |
´ø¿í |
20 MHz (10 MHz on ¡À50 mV range) |
ͨµÀÊý |
2 |
4 |
´¹Ö±·Ö±æÂÊ |
12 bits |
16 bits |
¶¯Ì¬·¶Î§ |
72 dB |
¾«¶È |
¡À1% |
ÉÏÉýʱ¼ä |
17.5 ns (calculated) on all ranges except 50 mV; 35 ns (calculated) on 50 mV range |
ÁéÃô¶È |
10 mV/div to 20 V/div |
ÊäÈ뷶Χ(Âú¿Ì¶È£© |
¡À50 mV to ¡À100 V in 11 ranges |
ÊäÈëÌØÐÔ |
1 M¦¸ in parallel with 22 pF |
ÊäÈëÀàÐÍ |
Single-ended, BNC connector |
ÊäÈëñîºÏ |
Software selectable AC/DC |
¹ýÔØ±£»¤ |
¡À200 V on single input |
×î´ó²ÉÑùÂÊ£¨µ¥·¢£© ʹÓÃ1 »ò 2¸öͨµÀ ʹÓÃ3 »ò 4¸öͨµÀ |
80 MS/s
80 MS/s 20 MS/s
»º´æ |
32 M samples shared between active channels |
Up to 1000 waveforms |
ʱ»ù·¶Î§ |
100 ns/div to 200 s/div |
ʱ»ù¾«¶È |
50 ppm with <= 10 ps jitter |
Ô´ |
ÈκÎÊäÈëͨµÀ |
»ù±¾´¥·¢ |
Auto, repeat, single, none |
Rising edge, falling edge, edge with hysteresis, pulse width, runt pulse, dropout, windowed |
×î´óÔ¤´¥·¢ÑÓ³Ù |
10 x ¡°per division¡± timebase setting |
×î´óºó´¥·¢ÑÓ³Ù |
50 s |
ƵÆ×·ÖÎöÒÇ |
´ø¿í |
20 MHz |
ƵÂÊ·¶Î§ |
DC to 20 MHz |
×î´óbinÊý |
1,048,576 |
ÏÔʾģʽ |
Magnitude, peak hold, average |
´°¿ÚÀàÐÍ |
Blackman, gaussian, triangular, hamming, hann, blackman-harris, flat-top, rectangular |
PC񻂗 |
×îС |
Processor: Pentium II processor, or equivalent Memory: 64 MB (XP) / 512 MB (Vista) minimum Operating system: Microsoft Windows XP SP2 or Vista (32-bit only) Ports: USB 1.1 compliant port |
½¨Òé |
Processor: 2 GHz Pentium IV processor, or equivalent Memory: 256 MB (XP) / 1 GB (Vista) Operating system: Microsoft Windows XP SP2 or Vista (32-bit only) Ports: USB 2.0 compliant port |
»·¾³ |
²Ù×÷»·¾³ ζȷ¶Î§ |
0 ¡ãC to 45 ¡ãC (15 ¡ãC to 40 ¡ãC for quoted accuracy)
´æ·Å»·¾³ ζȷ¶Î§ ʪ¶È |
-20 to +60¡ãC 5 to 95% RH, non-condensing
ÎïÀí³ß´ç |
³ß´ç |
200 x 140 x 35 mm (approx 7.9 x 5.5 x 1.4 in) |
ÖØÁ¿ |
<500 g (approx 1.1 lb) |
Èí¼þ |
PicoScope 6 for Windows |
PicoScope 6 is your complete test and measurement lab in one application. Features include: Capture modes - oscilloscope, spectrum and persistence modes Channel maths - calculate the sum, dfference, product, inverse or create your own custom function using standard arithmetic, exponential and trigonometric functions Automated measurementsScope mode: AC RMS, cycle time, DC average, duty cycle, falling rate, fall time, frequency, high pulse width, low pulse width, maximum, minimum, peak-to-peak, rise time and rising rate Spectrum mode: frequency at peak, amplitude at peak, total power, total harmonic distortion (THD), total harmonic distortion plus noise (THD+N), spurious-free dynamic range (SFDR), signal+noise+distortion to signal+noise ratio (SINAD), signal to noise ratio (SNR) and intermodulation distortion (IMD) Export data formats - Comma separated values (CSV), tab delimited (TXT), windows bitmap (BMP), graphics interchange format (GIF), portable network graphics (PNG), MATLAB 4 format (MAT) Full details on PicoScope 6 |
LinuxÇý¶¯ |
32-bit and 64-bit |
Èí¼þ¿ª·¢°ü |
A growing collection of drivers and example code for various programming languages |
ÓïÑÔÖ§³Ö |
Software PicoScope 6 |
Full support for English and German; menus only for Spanish, Italian, Hungarian and Simplified Chinese
Documentation User¡¯s guide Programmer¡¯s guide |
English, French, German, Italian, Spanish English
³£¹æ |
Additional hardware (supplied) |
USB 2.0 cable, user manuals, software CD-ROM |
PC interface |
USB 2.0 (USB 1.1 compatible) - cable supplied |
Power requirements |
Powered from USB port |
Compliance |
FCC (EMC), CE (EMC and LVD), RoHS compliant |
Total Satisfaction Guarantee |
In the event that this product does not fully meet your requirements you can return it for an exchange or refund. To claim, the product must be returned in good condition within 14 days. |
Warranty |
2 years |
Price: Oscilloscope |
¡ê499.00 $ 823.35* € 623.75* |
¡ê799.00 $ 1318.35* € 998.75* |
Price: Oscilloscope Kit (Oscilloscope, probes and carry case) |
¡ê519.00 $ 856.35* € 648.75* |
¡ê825.00 $ 1361.25* € 1031.25* |
* US Dollar and Euro prices are approximate. Note: quoted specifications apply when using PicoScope 6 software. Need to know a specification not listed here? - just ask |
