ATTRIBUTES / CHARACTERISTICS
| Input Range: |
0 to +100 mV |
| Output Range: |
0 to 1 mA |
| Mechanical Format: |
Modular plug-in-board |
| Isolation Voltage: |
1500 Vrms |
| Isolation Type: |
Transformer 3-way |
| Accuracy: |
¡À0.25% span |
| Supply Voltage: |
+5VDC ¡À5% |
| Input Voltage/Current Withstand: |
480 Vpeak |
| Gain/Offset Adjust: |
N/A |
| Module Bandwidth: |
45 to 20,000 Hz |
| External I-to-V Resistor: |
N/A |
| Output Control: |
Enable/Disable |
| Output Resistance: |
50 Ohms |
| Dimensions: |
2.28 x 2.26 x 0.60 inches |
| Interface: |
14 pin |
| Customization: |
yes |
