Form Factor |
Mini-ITX Motherboard |
Processor |
Intel® Core8482; i7 / i5 / i3 / Pentium® Desktop processor
Package Type: FCLGA1156
Bus Speed: 2.5GT/s DMI |
Memory |
2 x 240-pin DDR3 1066/1333 MT/s DIMM up to 8GB
(ECC memory supportability depends on CPU) |
Chipset |
Intel® BD82Q57 PCH (Platform Controller Hub) |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
Serial ATA Interface |
Intel® Q57 PCH built-in 4 x Serial ATA II interface up to 300MB/s
Support RAID 0, 1, 5, 10 and Intel® Rapid Storage Technology |
VGA Interface |
Intel® Core8482; integrated HD Graphics Technology |
Video Memory |
Up to 1.7GB shared with system memory |
Audio Interface |
Intel® integrated Q57 with Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extended Interface |
One x16 PCIe, 1 x Mini-PCIe, 1 x Mini-PCI |
Internal I/O Port |
1 x RS232/422/485, 1 x GPIO, 1 x CDIN, 1 x SMBus,
1 x Audio, 1 x IrDA, 4 x USB2.0 |
External I/O Port |
1 x PS/2 keyboard/mouse, 2 x RJ45, 1 x VGA, 4 x USB2.0,
1 x Audio, 3 x RS232 |
External Audio |
Line-in, MIC-in, Front, Rear, Center/Subwoofer and optical SPDIF |
Power Requirement |
Standard 24-pin ATX power supply and P4 4-pin 12V.
(20-pin is compatible) |
Board Dimension |
170mm x 170 mm (L x W) |
Temperature |
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC |
