Form Factor |
PICMG 1.0 Full-size CPU card |
CPU |
Intel® Atom N270 (1.6GHz) @ 533MHz FSB |
Memory |
1 x 200-pin DDR2 SO-DIMM support 400/533 MHz up to 2GB |
Chipset |
Intel® 945GSE & ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset interval timer for 1min(sec) ~
255min(sec) |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel integrated extreme GMA 950 Technology
Optional secondary VGA connector (FE-97GT2XG / G2) |
Video Memory |
Up to 224MB shared with system memory |
LVDS Interface |
Onboard 18-bit dual channel LVDS interface
Optional secondary 18-/24-bit dual channel LVDS interface with
+3.3V / +5V / +12V power supply (FE-97GTX2G / G2) |
DVI Interface |
Optional DVI interface (FE-97GTXDG / G2) |
Solid State Disk |
IDE supports 44-Pin DiskOnModule with +5V power supply
1 x Compact Flash Type II socket |
Serial ATA Interface |
2 x SATA interface with 150MB/s transfer rate |
Audio Interface |
Intel® ICH7M integrated with ALC655 Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Expansion Interface |
2 x Mini PCIe (shared together with internal USB header)
1 x Mini PCI |
Internal I/O Port |
1 x IrDA, 1 x GPIO, 1 x Audio, 1 x CDIN, 1 x LVDS, 6 x USB,
1 x RS232/422/485, 5 x RS232, 1 x LCD inverter, 2 x SATA,
1 x HDTV, 1 x FDD, 1 x LPT |
External I/O Port |
1 x DB15 VGA port, 1 x PS/2 keyboard & mouse port,
2 x RJ45 port |
Power Requirement |
+5V, +12V & 5VSB |
Board Dimension |
338mm x 122 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
