Form Factor |
Mini-ITX motherboard |
CPU |
Intel® Atom8482; N450, 1.66GHz, 512KB cache (LV-67EG)
Intel® Atom8482; D410, 1.66GHz, 512KB cache (LV-67EH)
Intel® Atom8482; D510, 1.66GHz, 1MB cache (LV-67EA)
Package type : Micro-FCBGA (FCBGA559) |
Memory |
1 x 200-pin DDR2-667 SO-DIMM up to 2.0 GB (LV-67EG)
1 x 200-pin DDR2-667 SO-DIMM up to 4.0 GB (LV-67EH/A)
Support Non-ECC, unbuffered memory only |
Chipset |
Intel® ICH8M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min/sec ~ 255min/sec |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
Integrated Graphics |
Intel® integrated extreme GMA 3150 Technology |
Video Memory |
Up to 384MB shared with system memory |
LVDS Interface |
Chipset Integrated 18-bit single channel LVDS |
Serial ATA Interface |
3 x SATAII interface with 300MB/s transfer rate |
Solid State Disk |
1 x Compact Flash Type-II, 1 x 44-pin IDE |
Audio Interface |
Intel® ICH8M integrated with Realtek ALC888 HD Codec |
LAN Interface |
2 x Intel® 82583V Gigabit Ethernet controller |
| GPIO Interface |
Onboard programmable 8-bit Digital I/O interface |
Expansion Interface |
1 x PCI slot, 2 x PCIe mini card & 1 x Mini-PCI sockets |
Internal I/O Port |
1 x Audio, 4 x USB2.0, 1 x LVDS, 1 x LCD Inverter, 1 x LPT
3 x RS232, 1 x SMBUS, 1 x IrDA, 1 x GPIO |
External I/O Port |
4 x USB, 2 x RJ45 LAN, 1 x DB15 VGA, 1 x Audio, 1 x SPDIF 1 x RS232/422/485, 2 x RS232, , 1 x PS2 keyboard/mouse |
Power Requirement |
DC 9V ~ 24V input or standard 20-pin ATX power supply |
Board Dimension |
170mm x 170mm |
Temperature |
Operating within 0~60 centigrade
Storage within -20~85 centigrade |
