| ÐͺÅÊýÁ¿ |
ÄÚÈÝ |
FWA-700 |
Tabletop Internet Security Platform with 4 Rear LAN Ports |
FWA-60A |
´ø 3 ¸öºó¶Ë LAN ¶Ë¿ÚºÍ PCI À©Õ¹²ÛµĄ̈ʽ Internet °²È«Æ½Ì¨ |
FWA-300 |
Coming Soon!! The FWA-300 is a compact and power efficient tabletop Internet Security Platform designed for entry-level SMB/SOHO/Home offices security applications. The platform is driven by the power saving VIA C7 CPU, combined with VIA CX700 chipset, making it the ideal alternative for an economical entry level security solution. The VIA C7? processor has built-in PadLock? Security Engine which acts as a fast and reliable hardware security accelerator without the added cost of an extra add-on card. With the Marvell 8001 Ethernet controllers, the FWA-300 provides four Gigabit Ethernet (GbE) LAN ports for robust connectivity. The FWA-300 supports optional IDE, which effectively enhances the implementation of many internet security applications such as IDS/IPS, anti-virus, and VPN Gateways. A CompactFlash slot is available for OS and application s, which can be easily accessed and replaced through an easy removable cover on the back. Plus there are LED indicators on the front panel to display platform status and a 9-pin RS-232 serial port for local system management, maintenance and diagnostics. The FWA-300 is FCC, CE, UL and RoHS compliant. For more information on VIA PadLock? Security Engine, please visit http://www.via.com.tw/en/initiatives/padlock/index.jsp |
FWA-660 |
±³Ãæ´ø 4 ¸öÒÔÌ«Íø¶Ë¿ÚµÄ½ô´ÕÐÍ Internet °²È«Æ½Ì¨ |
SG-1003 |
°²È«Íø¹Ø£¬ÕûºÏ3¸öÍø¿Ú |
FWA-3700 |
1U Rackmount Intel? Pentium? M based Platform with 4 Front Marvell GbE Ports and One PCIe Expansion Slot |
FWA-3140 |
´ø 4 ¸öǰ¶Ë LAN ¶Ë¿ÚºÍË« PCI À©Õ¹²ÛµÄ»ú¼Ü°²×° Internet °²È«Æ½Ì¨ |
FWA-3180 |
10/100/1000 ¸ßËÙÒÔÌ«Íø¶Ë¿Ú |
FWA-3300 |
´ø 3 ¸öÒÔÌ«Íø¶Ë¿ÚµÄ»ú¼Ü°²×° Internet °²È«Æ½Ì¨ |
FWA-3620 |
´ø 3 ¸öǰ¶Ë LAN ¶Ë¿ÚºÍË« PCI À©Õ¹²ÛµÄ»ú¼Ü°²×° Internet °²È«Æ½Ì¨ |
FWA-3660 |
´ø 4 ¸öÒÔÌ«Íø¶Ë¿ÚºÍ LCD ÏÔʾµÄ»ú¼Ü°²×° Internet °²È«Æ½Ì¨ |
FWA-3680 |
FWA-6280A |
Ë«ÖÁÇ¿EM64T(NOCONA),×î¸ßÖ§³Ö3.2GHZ |
