ÐͺÅÊýÁ¿ |
ÄÚÈÝ |
ACP-1000 |
1U 2-PCI 64/32λ´øÇ°USB/PS2²å¿ÚµÄÉϼÜʽ»úÏä |
ACP-2000 |
2U 6²Û/5²Û£¬Ç°USB/PS2²å¿ÚµÄÉϼÜʽ»úÏä |
IPC-602 |
2U6²ÛÉϼÜʽ¹¤Òµ»úÏä |
IPC-630 |
4U Rackmount Chassis for General Purpose Industrial Applications |
ACP-4320 |
4U Rackmount Chassis with Front-Accessible SATA HDD Trays for Easy Maintenance |
ACP-4000 |
4U 14²Û´øÇ°¶Ë USB/PS2½Ó¿ÚµÄÉϼÜʽ»úÏä |
IPC-623 |
4U 20²ÛÈÝ´íʽ¹¤Òµ¿ØÖƼÆËã»ú |
IPC-611 |
4U 14²ÛÉϼÜʽ»úÏ䣬´øÇ°Ö÷çÉÈ |
IPC-610-L |
4U¸ß14²Û±³°å¼Ü×°¹¤Òµ»úÏ䣬ÅäÖÃÇ°Ö÷çÉÈ |
IPC-610-H |
4U¸ß14²ÛÉϼÜʽ»úÏäÇ°Öà USB/PS2½Ó¿Ú |
IPC-610-F |
´ø ATX Ö÷°åÑ¡ÏîµÄ 4U ¸ß 14 ²Û»ú¼Ü°²×°»úÏä |
IPC- 510 |
The IPC-510 is a 19"£» rackmount industrial computer chassis for mission-critical applications. This unit can accommodate a 14-slot PCI/ISA bus passive backplane or a standard ATX motherboard and supports versatile power supplies. A lockable door in the front secures the unit from any unauthorized access. One hot-swap filtered cooling fan maintains positive air circulation through the whole chassis. With its hold-down clamp and shock mounted drive brackets, the IPC-510 can withstand shock, vibration and dust found in harsh environments. |
ACP-5260 |
5U Rackmount Chassis with 6 Hot Swap Ultra320 SCSI SCA HDD Trays and Redundant Power Supply |
IPC-622 |
6U 20²Û´øÈȲå°ÎÈßÓàµçÔ´ÈÝ´í»úÏä |
ACP-7000 |
7U 20²ÛÉϼÜʽ»úÏä |
IPC-6908 |
8²ÛÈÝ´íIPC»úÏä |
IPC-6608 |
8²ÛIPC»úÏä |
IPC-6806 |
6²Ų̂ʽ/±Ú¹Òʽ½ô´ÕÐ͹¤¿Ø»ú |
IPC-6606 |
6²ÛÈÝ´íIPC»úÏä |
IPC-644 |
4²å²Û½ô´ÕÐÍ×ÀÃæ/±Ú¹Òʽ»úÏ䣬´ø¿ª¼ÜʽAC/DCµçÔ´ |
IPC-6006 |
6²Û°å¿¨°²×°¼Ü |
