Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÏßÀÂÅä¼þ
²úÆ·Ãû³Æ£º ÏßÀÂÅä¼þ
ÐÍ ºÅ£º
ÐͺÅÊýÁ¿  ÄÚÈÝ
  1700000265 ATX-20P(M)/12P(F) µçÀ£¬10 ÀåÃ×£¬ÓÃÓÚ PCM-9581
  1700000601 USB 4 ¶Ë¿Ú/10P-2.0mm2 µçÀ£¬30.5 ÀåÃ×
  1700000644 IEEE1394*2/10P-2.54 mm2 µçÀ£¬25 ÀåÃ×
  1700000719 USB 4 ¶Ë¿Ú/10P-2.54mm*2µçÀ£¬30.5 ÀåÃ×
  1700000720 IEEE1394*3/10P-2.54 mm*3 µçÀ£¬25 ÀåÃ×
  1700060202 20cm 6Õë-6Õë-6Õë PS/2¼üÅ̺ÍÊó±êÏßÀÂ
  1700090301 ASS¡®Y COM ¶Ë¿ÚµçÀ£¬30 ÀåÃ×£¬D-SUB 9P µ½ 4P 2.0 ºÁÃ×
  1700100250 ASS¡®Y COM ¶Ë¿ÚµçÀ£¬250 ÀåÃ×£¬D-SUB 9P µ½10P 2.0 ºÁÃ×
  1700160000 PCM-5862 16ÕëÒôƵ½Ó¿ÚµçÀÂ
  1700160160 PCM-5820/L 16 ÕëÒôƵµçÀ£¬16 ÀåÃ×£¨2.0 ºÁÃ×£©
  1700260250 ASS¡®Y LPT ¶Ë¿ÚµçÀ 25 ÀåÃ× 25P µ½ 26P 2.0 ºÁÃ×
  1701080300 Flat cable 8P 30 ÀåÃ× FD-0800-30
  1701100202 Flat cable 20 ÀåÃ× IDC10P 2.0ºÁÃ×/RJ45 PCM-9570
  1701100300 Flat cable 10P 30 cm gray D-SUB (9P-10P)
  1701140201 Flat 14Õë 2.0 mm 20 cm secondary¶Ë¿Ú9Õë(M)
  1701140300 Flat cable 14P-2.0 mm 30 cm
  1701160101 ASS¡®Y VGA µçÀÂ10 ÀåÃ× D-SUB 15P to 16P 2.0 ºÁÃ×
  1701160150 Cable VGA 15 cm D-SUB 15P to 16P 2.0 mm PCM-9550
  1701200180 Cable VGA 15 cm D-SUB 15P to 16P 2.0 mm PCM-9550
  1701340603 Flat cable 34P 60 cm FC34/34/HOUSING34 Idiot-proof
  1701340700 FLAT CABLE 34P 70cm GRAY 5.25"£» &£» 3.5"£» FDD
  1701400181 FLAT CABLE 18CM IDC40P 2.0mm/4COM PCM-9570 USE
  1701400452 20ÕëDMA-66ÓÃ45cm40ÕëÅÅÏß
  1701400601 FLAT CABLE 40P 60cm GRAY FOR 2 AT BUS HDD
  1701440350 FLAT CABLE 44P 35cm GRAY IDC44P/IDC44P/IDC44P
  1701440500 FLAT CABLE 40P 50cm GRAY IDC40P/IDC40P/HOUSING44P
  1701440504 Flat Cable 44P 50cm IDC 44P/44P/40P keyed
  1703030300 Wire 3P-3P 30cm WHT/BLK/ BLU for PCM-9570
  1703050306 Wire 30cm 5P TV-out (S-Video, Comp. -Video)
  1703060053 Cable 6P(MINI-DIN)-6P(Wa fer 2.0mm) 5cm
  1703060191 Cable 6P-2.0mm Housing/ 6P (PS/2)/6P (K/B) 19cm
  1703080101 Wire 7P/Big 4P*2 10cm
  1703100121 Wire 10P 12cm IDC 2.0mm For USB 2 PORT MBPC USE
  1703100152 Audio Cable 10P 2.0mm 15cm for PCM-9372
  1703140300 RCA Jack S-video 30cm 14P 2mm video in/out
  1703200380 Wire ATX 20P/8P+3P+3P 38cm for PCM-3370
  1703400156 Wire DF13-40P/4 COM 15cm for PCM-9580
  9681000044 Purch 26-34 ÕëÈíÇýµçÀÂת»»Æ÷ (+5V)
  9689000002 ÃÔÄãÌøÏßñ£¬10 Ƭװ£¨ºÚÉ«£©
  9689000068 Purch ÌøÏß°ü Y * 15 + R * 5+#1BAG
¹«Ë¾Ãû³Æ£º ±±¾©³ÏÑǿƼ¼ÓÐÏÞÔðÈι«Ë¾
µç »°£º 010 53258989 / ÖìС½ã
ÊÖ»ú£º
µØ Ö·£º ±±¾©Êк£µíÇøË«Çå·3ºÅÖÐÌ«´óÏÃ31010ÊÒ
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.cyent.com.cn
  • »¯¹¤¿Ø»úϵÁвúÆ·£ºMIC-3100
  • MIC-3612 4¶Ë¿ÚRS-232/422/485º¬ÀËÓ¿±£»¤µÄͨѶ¿¨
  • MIC-3716 3U CompactPCI²É¼¯¿¨
  • MIC-3323 3U CompactPCIϵͳ¿ØÖÆÆ÷
  • MIC-3620 3U CompactPCIͨѶ¿¨
  • MIC-3001 CompactPCI»úÏä
  • MIC-3321 3U CompactPCI ¿ØÖÆÆ÷
  • MIC-3002 6²Û3U CompactPCI »úÏä
  • CPCI»úÏä
  • CPCI»úÏä
