Form Factor |
Half-size PCI-bus SBC |
CPU |
Intel® Atom™ N450, 1.66GHz, 512KB cache (HE-772G)
Intel® Atom™ D410, 1.66GHz, 512KB cache (HE-772H)
Intel® Atom™ D510, 1.66GHz, 1MB cache (HE-772A)
Package type : Micro-FCBGA (FCBGA559) |
Memory |
1 x 200-pin DDR2-667 SO-DIMM up to 2.0 GB (HE-772G)
1 x 200-pin DDR2-667 SO-DIMM up to 4.0 GB (HE-772H/A)
Support Non-ECC, unbuffered memory only |
Chipset |
Intel® ICH8M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min/sec ~ 255min/sec |
Power Management |
ACPI 2.0 compliant, supports power saving mode |
Integrated Graphics |
Intel® integrated extreme GMA 3150 Technology |
Video Memory |
Up to 384MB shared with system memory |
LVDS Interface |
Chipset Integrated 18-bit single channel LVDS |
Serial ATA Interface |
3 x SATAII interface with 300MB/s transfer rate |
Solid State Disk |
1 x Compact Flash Type-II, 1 x 44-pin IDE |
Audio Interface |
Intel® ICH8M integrated with Realtek ALC888 HD Codec |
LAN Interface |
2 x Intel® 82583V Gigabit Ethernet controller |
| GPIO Interface |
Onboard programmable 8-bit Digital I/O interface |
Expansion Interface |
2 x PCIe mini card sockets |
Internal I/O Port |
1 x Audio, 6 x USB2.0, 1 x LVDS, 1 x LCD Inverter, 1 x LPT
1 x RS232/422/485, 5 x RS232, 1 x SMBUS, 1 x IrDA, 1 x GPIO |
External I/O Port |
2 x RJ45 LAN, 1 x DB15 VGA, 1 x PS2 keyboard/mouse |
Power Requirement |
DC 5V & 12V power required, optional 5VSB for ATX |
Board Dimension |
185mm x 122mm |
Temperature |
Operating within 0~60 centigrade
Storage within -20~85 centigrade |
