Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÎÈѹÎÈÆµµçÔ´
²úÆ·Ãû³Æ£º ÎÈѹÎÈÆµµçÔ´
ÐÍ ºÅ£º AF50
Æ· ÅÆ£º 6461
   1¡¢Capacity£º          600KVA
2¡¢Input£º
Voltage£º    AC230V-460V    Frequency£º30-80HZ
Phase£ºThree-phase four-wire system
3¡¢Output£º
Voltage£º AC380V¡À1%      Frequency£º 50/60   Hz
Voltage Stability£º  ¡Ü       1      %
Frequency Stability£º¡Ü     0.01       %
wave shape distortion£º¡Ü     3     %
4.Over load capacity : with high over load capacity ,the transition current can endure two times rated current .
5. Protection£ºOutput Circuit Breaker, Electronic Circuits Instant Trip for Over Voltage, Over Load, Over Temperature, Short Circuit Protection and Alarm System
6. working environment£º
             working temperature£º-10¡æ¡«45¡æ
             relative humidity£º¡Ü90£¥£¨25¡æ£©
7. method of operation display£ºdisplay  Voltage£¨V£©¡¢Frequency£¨Hz£©¡¢Current£¨A£©and Wattmeter£¨W£©
8.the apply load :without limited .suit complete unbalance load ,but the motor and Inductance load must reduced the value apply
¹«Ë¾Ãû³Æ£º Î÷°²½ÜÈð´ïÒÇÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 029 86609982 / ¸ßÓñ
ÊÖ»ú£º 18992811978
µØ Ö·£º Î÷°²ÊÐδÑëÇøºº³ÇÉÌÒµ½Ö8ºÅ
ÓÊ ±à£º 710018
Ö÷ Ò³£º http://www.acsoon.com
  • Ìì½òºÓ±±É½Î÷±±¾©ÖÐÆµµçÔ´Éú²ú
  • ±±¾©Äæ±äʽÎÈѹÎÈÆµµçÔ´
  • ±±¾©µ¥½øµ¥³öÖÐÆµµçÔ´
  • 400HZÖÐÆµÄæ±äµçÔ´
  • ÈýÏà±äƵµçÔ´|Ìì½ò500KW±äƵµçÔ´
  • ±±¾©µ¥Ïà|ÈýÏֱཻ½»ÎÈѹµçÔ´
  • ½ÜÈð´ï200VA~1250KVAµçÔ´
  • 400HZ-115V-500VAPOWER
  • ±±¾©¹ú·Àµ¥Î»×¨¹©ÖÐÆµµçÔ´
  • ±±¾©ÈýÏàÄæ±äµçÔ´
