ÌØµã
¡ï¸ß¸ÐӦƵÂÊ ¡ïʹÓÃÊÙÃü³¤¡¢¸ß¿É¿¿ÐÔ
¡ïÄÚ²¿Ôª¼þÈ«²¿²ÉÓýø¿Ú¼þ ¡ï¶Ì·¡¢¼«ÐÔ·´½Ó±£»¤
¡ï¿É°²×°ÏÁС¿Õ¼ä ¡ï·ÀË®µÈ¼¶£ºIP67£¬¿ÉÔÚË®ÖÐÓ¦Óà |
Ö±Á÷3Ïß/DC 3-Wire |
ÐͺÅ/type |
NPN.NO |
FN0.8-M5-NOD1 |
NPN.NC |
FN0.8-M5-NCD1 |
NPN.NO+NC |
PNP.NO |
FN0.8-M5-POD1 |
PNP.NC |
FN0.8-M5-PCD1 |
PNP.NO+NC |
ÍâÐιæ¸ñ/Form Factor |
M5*30 |
°²×°·½Ê½/Installation |
Æëƽ/shielded |
¼ì²â¾àÀë/Sensing distance |
0.8mm |
½¨Òé¾àÀë/Recommended distance |
0¡0.6mm |
¿ª¹ØÆµÂÊ/switching frequency |
2500Hz |
ÖØ¸´¾«¶È/Repeatability |
¡Ü5% |
³ÙÖÍ/Hysteresis |
¡À10% |
±£»¤µç·/Protection circuit |
¶Ì·¡¢¼«ÐÔ·´½Ó±£»¤ |
µçѹ½µ/Voltage drop |
¡Ü1.5V DC |
µçÔ´µçѹ/Supply voltage |
10-30V DC |
¸ºÔصçÁ÷/Output current |
¡Ü200mA |
¿ÕÔØµçÁ÷/No-load supply current |
¡Ü10mA |
Êä³öÏÔʾ/Output Display |
ÂÌɫָʾµÆ/Green LED |
¹¤×÷ζȷ¶Î§/Operating temperature |
-25¡70¡æ |
»·¾³Êª¶È/Humidity |
35-95%RH |
Íâ¿Ç²ÄÁÏ/Housing material |
¶ÆÄø»ÆÍ/nickel plated brass |
Á¬½Ó·½Ê½/Connection |
2Ã×µçÀÂ/2m Cable |
ÍâÐÎ³ß´ç £¨µ¥Î»mm£© |
