ÌØµã
¡ï¸ÐÓ¦¾àÀ볤£¬°²×°¼òµ¥ ¡ïʹÓÃÊÙÃü³¤¡¢¸ß¿É¿¿ÐÔ
¡ïÄÚ²¿Ôª¼þÈ«²¿²ÉÓýø¿Ú¼þ ¡ï¶Ì·¡¢¼«ÐÔ·´½Ó±£»¤
¡ïÍêÈ«¿É´úÌæ½ø¿ÚͬÀà²úÆ· ¡ï·ÀË®µÈ¼¶£ºIP67£¬¿ÉÔÚË®ÖÐÓ¦Óà |
Ö±Á÷3Ïß/DC 3-Wire |
ÐͺÅ/type |
NPN.NO |
FN40-PA100-NOD1 |
MN60-PA100-NOD1 |
NPN.NC |
FN40-PA100-NCD1 |
MN60-PA100-NCD1 |
NPN.NO+NC |
PNP.NO |
FN40-PA100-POD1 |
MN60-PA100-POD1 |
PNP.NC |
FN40-PA100-PCD1 |
MN60-PA100-PCD1 |
PNP.NO+NC |
ÍâÐιæ¸ñ/Form Factor |
¦Õ80 |
°²×°·½Ê½/Installation |
Æëƽ/shielded |
·ÇÆëƽ/unshielded |
¼ì²â¾àÀë/Sensing distance |
40mm |
60mm |
½¨Òé¾àÀë/Recommended distance |
0¡32.0mm |
0¡50.0mm |
¿ª¹ØÆµÂÊ/switching frequency |
50Hz |
80Hz |
ÖØ¸´¾«¶È/Repeatability |
¡Ü5% |
³ÙÖÍ/Hysteresis |
¡À10% |
±£»¤µç·/Protection circuit |
¶Ì·¡¢¼«ÐÔ·´½Ó±£»¤ |
µçѹ½µ/Voltage drop |
¡Ü1.5V DC |
µçÔ´µçѹ/Supply voltage |
10-30V DC |
¸ºÔصçÁ÷/Output current |
¡Ü200mA |
¿ÕÔØµçÁ÷/No-load supply current |
¡Ü10mA |
Êä³öÏÔʾ/Output Display |
»ÆÉ«Ö¸Ê¾µÆ/Yellow LED |
¹¤×÷ζȷ¶Î§/Operating temperature |
-25¡70¡æ |
»·¾³Êª¶È/Humidity |
35-95%RH |
Íâ¿Ç²ÄÁÏ/Housing material |
ABS¹¤³ÌËÜÁÏ |
Á¬½Ó·½Ê½/Connection |
2Ã×µçÀÂ/2m Cable |
Ö±Á÷2Ïß/DC 2-Wire |
ÐͺÅ/type |
NO |
FN40-PA100-DOD1 |
MN60-PA100-DOD1 |
NC |
FN40-PA100-DCD1 |
MN60-PA100-DCD1 |
¦Õ80 |
Æëƽ/shielded |
Æëƽ/shielded |
40mm |
60mm |
0¡32.0mm |
0¡50.0mm |
40Hz |
60Hz |
¡Ü5% |
³ÙÖÍ/Hysteresis |
¡À10% |
¶Ì·¡¢¼«ÐÔ·´½Ó±£»¤ |
¡Ü6V DC |
10-30V DC |
¡Ü200mA |
¡Ü10mA |
-25¡70¡æ |
»·¾³Êª¶È/Humidity |
35-95%RH |
ABS¹¤³ÌËÜÁÏ |
2Ã×µçÀÂ/2m Cable |
½»Á÷2Ïß/AC 2-Wire |
ÐͺÅ/type |
SCR.NO |
FN40-PA100-AOA1 |
MN60-PA100-AOA1 |
SCR.NC |
FN40-PA100-ACA1 |
MN60-PA100-ACA1 |
¦Õ80 |
Æëƽ/shielded |
Æëƽ/shielded |
40mm |
60mm |
0¡32.0mm |
0¡50.0mm |
15Hz |
20Hz |
¡Ü5% |
³ÙÖÍ/Hysteresis |
¡À10% |
Ó¿À˱£»¤ |
¡Ü8V AC |
20-250V AC |
¡Ü400mA |
¡Ü3mA |
-25¡70¡æ |
»·¾³Êª¶È/Humidity |
35-95%RH |
ABS¹¤³ÌËÜÁÏ |
2Ã×µçÀÂ/2m Cable |
ÍâÐÎ³ß´ç £¨µ¥Î»mm£© |
