1¡¢Capacity£º 600KVA
2¡¢Input£º
Voltage£º AC230V-460V Frequency£º30-80HZ
Phase£ºThree-phase four-wire system
3¡¢Output£º
Voltage£º AC380V¡À1% Frequency£º 50/60 Hz
Voltage Stability£º ¡Ü 1 %
Frequency Stability£º¡Ü 0.01 %
wave shape distortion£º¡Ü 3 %
4.Over load capacity : with high over load capacity ,the transition current can endure two times rated current .
5. Protection£ºOutput Circuit Breaker, Electronic Circuits Instant Trip for Over Voltage, Over Load, Over Temperature, Short Circuit Protection and Alarm System
6. working environment£º
working temperature£º-10¡æ¡«45¡æ
relative humidity£º¡Ü90£¥£¨25¡æ£©
7. method of operation display£ºdisplay Voltage£¨V£©¡¢Frequency£¨Hz£©¡¢Current£¨A£©and Wattmeter£¨W£©
8.the apply load :without limited .suit complete unbalance load ,but the motor and Inductance load must reduced the value apply
