LCD size 5.6inch
Driver element a-Si TFT active matrix
Resolution 640*(RGB)*480
Display mode Normally White, Transmissive
Dot pitch 0.588(W)*01764(H)mm
Active area 112.896(W)*84.672(H)mm
Module size 126.5(W)*100(H)*7.2(D)mm
Surface treatment Anti-Glare
Color arrangement RGB-stripe
Interface Digital
Backlight Power consumption 1.900W(Typ)
Panel Power consumption 0.660W(Typ)
Weight 127.5g
