TPI-665/655L£¨ÒºÌåÐÍ£© Êý¾Ý¼Ç¼ѹÁ¦±íÏêϸ×ÊÁÏFeatures
Measurement Range: ¡À101.5 psi (¡À7bar)
Display: 5 Digit Dual line LCD with backlight
Input Type: Differential (1/4¡± NPT)
Resolution (max): 0.01 psi (0.001 bar) (0.1 inH2O)
Accuracy: 0.2% Full scale
Repeatability: 0.1% Full scale
Mean Temperature Coefficient: 0.1% of reading per ºC
Functions: One Touch Zero, Data Hold, Back-light, Unit Selection, Data
Logging, Auto power Off, Min / Max Record,
Resolution Selection
Units of Measure: 7Units (bar, kPa, PSI, mmHg, inHg, mmH2O, inH2O)
Data logging: 5000 Data, 1sec ~ 24 hour.
Data Storage: 16 data points
Communication: IR to USB Interface and PC Application software
(optional p/n A665)
Battery Type: AA(1.5V)*2 alkaline (MN1500, LR6)
Battery Life: 600hour (Typical)
Auto Power Off: 20 minutes (can be disabled)
Standard Accessories (Included): two 1.5 Volt Alkaline Battery (A002),
Protective Boot w/ magnets (A614)
Differential input with +/-100psi range.
Seven units of measure (bar, kPa, PSI, mmHg, inHg, mH2O, inH2O).
Data Logging - Record test data with time stamp and display with optional
software.
PC Communication: IR to USB Interface and PC Application software
(optional p/n A665)
Printing - Print test results directly to the optional A740 IR printer
Display - 5 digit dual line with backlight
Data Storage - Save up to 16 readings.
Min / Max - Records Min/Max readings
Auto Off - Conserve batteries.
·Ö±æÂÊÑ¡Ôñ
¼ÆÁ¿µ¥Î»£º7ÖÖ (bar, kPa, PSI, mmHg, inHg, mmH2O, inH2O)
Êý¾Ý¼Ç¼£º5000±ÊÊý¾Ý£¬1Ãë12316;24Сʱ¡£
Êý¾Ý´æ´¢£º16¸öÊý¾Ýµã
ͨѶ£ººìÍâµ½USB½Ó¿ÚºÍPCÓ¦ÓÃÈí¼þ £¨¿ÉÑ¡p /nA665£©
µç³ØÀàÐÍ£ºAA(1.5V)*2 ¼îÐÔ (MN1500, LR6)
µç³ØÊÙÃü£º600Сʱ£¨µäÐÍ£©
×Ô¶¯¹Ø»ú£º20·ÖÖÓ£¨¿É¹Ø±Õ£©
±ê×¼¸½¼þ£¨°üÀ¨£©£º2¸ö1.5·ü¼îÐÔµç³Ø£¨A002£©
±£»¤Ì×W´ÅÌú£¨A614£©
²î·ÖÊäÈë + / - 100psi·¶Î§¡£
7ÖÖµ¥Î»£º(bar, kPa, PSI, mmHg, inHg, mmH2O, inH2O)
Êý¾Ý¼Ç¼ - ´øÓÐʱ¼ä´ÁºÍ¿ÉÑ¡µÄÏÔʾ¼Ç¼²âÊÔÊý¾Ý
Èí¼þ¡£
µçÄÔͨѶ£ººìÍâµ½USB½Ó¿ÚºÍPCÓ¦ÓÃÈí¼þ £¨¿ÉÑ¡p /nA665£©
´òÓ¡ - ´òÓ¡²âÊÔ½á¹ûÖ±½Óµ½Ñ¡¹ºµÄA740ºìÍâ´òÓ¡»ú
ÏÔʾ - 5λ´ø±³¹âµÄË«ÐÐ
Êý¾Ý´æ´¢ - ±£´æ×î¶à16¸ö¶ÁÊý¡£
×îС/×î´ó - ¼Ç¼×îС/×î´ó¶ÁÊý
×Ô¶¯¹Ø»ú - ±£»¤µç³Ø¡£
±¾ÎÄÀ´×Ô: Ì©ÄɿƼ¼(www.yitai17.com) Ïêϸ³ö´¦²Î¿¼£ºhttp://www.yitai17.com/shop/?9054.html
