TM-730ζÈ/ʪ¶È¼ÆÏêϸ×ÊÁÏTM-730
Temperature/Humidity Meter
DISPLAY:
Dual LCD displays:
The primary maximum reading 1999.
The secondary Maximum display: 999.
FUNCTIONS:
- Measuring humidity, temperature, wet bulb and dew point.
- Quick-response capacitance sensor.
- Max/Min/AVG and Data Hold.
- Auto power off and disable function.
- Low battery indication.
SPECIFICATIONS:
¹æ¸ñ£º
TM-730 Temperature/Humidity Meter
ζÈ/ʪ¶ÈÒÇ
Temperature ranges
ζȷ¶Î§ -20ºC C~50ºC
Temperature Resolution
ζȷֱæÂÊ 0.1ºC
Temperature update rate
ζȸüÐÂÂÊ 500ms
Relative humidity accuracy
Ïà¶Ôʪ¶È +/-3.5% @25ºC for 20% ~90% RH
+/- 5% for 1%~19.9% and 1%~99%RH
Relative Humidity Resolution
Ïà¶Ôʪ¶È·Ö±æÂÊ 0.1% RH
Second Relative Humidity response time
µÚ¶þÏà¶Ôʪ¶ÈµÍÓÚ10ÃëµÄÏìӦʱ¼ä
below 10 seconds
Power
µçÔ´ 2 batteries 1.5V AAA
Dimension
³ß´ç 107mm x48mm x23mm(L*W*H)
Weight
ÖØÁ¿ 80g
±¾ÎÄÀ´×Ô: Ì©ÄɿƼ¼(www.yitai17.com) Ïêϸ³ö´¦²Î¿¼£ºhttp://www.yitai17.com/shop/?9071.html
