Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ½Ó½ü¿ª¹ØLP-12KN
²úÆ·Ãû³Æ£º ½Ó½ü¿ª¹ØLP-12KN
ÐÍ ºÅ£º LP-12KN
¹©Ó¦½Ó½ü¿ª¹ØLP-12KN
ÍâÐμ°°²×°³ß´ç
Shape and install size
¼ì²âÌå Object Ìú¿é Steel 18 X 18 X 1mm Ìú¿é Steel 18 X 18 X 1mm Ìú¿é Steel 12 X 12 X 1mm Ìú¿é Steel 18 X 18 X 1mm
Ô¼¶¨¾àÀëStipulate distance 4mm 5mm 4mm 8mm
¼ì²â¾àÀëMounting distance 0~3.2mm 0~4mm 0~3.2mm 0~6.4mm
ƵÂÊFrequency ¡Ü300HZ ¡Ü300HZ ¡Ü250HZ ¡Ü200HZ
»Ø²îHysteresis СÓÚ10%Ô¼¶¨¾àÀë Less than 10% stipulate distance
µçÔ´µçѹPower voltage DC 12V~24V (DC 10~30V)
¿ØÖÆÊä³öContron output ´¿×è¸ºÔØ¡Ü200mA Resistive load:max 200mA ¸ÐÐÔ¸ºÔØ¡Ü100mA Inductive load: max100mA
ѹ½µResidual voltage ¡Ü2V (At DC 24V)
©µçÁ÷Leakage current £¼0.5mA (At DC 24V)
»·¾³Î¶ÈAmbient temprature -10¡æ ~ +65¡æ (-25¡æ ~ +70¡æ)
¾øÔµµç×èDielecttric strength ¡Ý100M¦¸ (At DC 500V)
¾øÔµÇ¿¶ÈDielecttric strength AC 110V 1min (At 50/60HZ)
ָʾIndication LED Red
·À»¤µÈ¼¶Deregg of protection IP66(IEC)
²ÄÁÏMaterial Case: ABS (Ê÷Ö¬) Face: ABS£¨Ê÷Ö¬£© Case: Brass£¨»ÆÍ­£© Face: ABS£¨Ê÷Ö¬£©
Èý¡¢ ½ÓÏßͼ CONNECTIONËÄ¡¢ °²×°¼°ÒªÇóÖ°HANDLING DEMAND
µ±°²×°½Ó½ü¿ª¹ØÊ±£¬ÖÜΧÓнðÊô£¬¿ª¹Ø¶ÔÖûò²¢Áв¼ÖÃʱ£¬ÇëÒÔ´óÓÚͼÖÐËùʾ³ß´ç°²×°£¬ ÒÔÃâÓ°Ï쿪¹Ø¿É¿¿¶¯×÷¡££¨Sn±íʾԼ¶¨¾àÀ룩
Handling the proimity Sensor as follow show to reliable acte , if used in an area surrounded by metal or juxtapose then,(Sn: Sensing disrance)
ƵÂÊÏìÓ¦¿ì£¬Ê¹ÓÃÊÙÃü³¤£¬¶¯×÷¿É¿¿£¬¿¹¸ÉÈÅÄÜÁ¦Ç¿£¬²¢¾ßÓÐÄÍÕñ¡¢Ä͸¯Ê´¡¢·ÀË®ÐԺõÈÌØµã¡£²úÆ·ÊÊÓÃÓÚ»úе¡¢»¯¹¤¡¢ÔìÖ½¡¢ÇṤµÈÐÐÒµ×÷ÏÞλ¡¢¶¨Î»¡¢¼ì²â¡¢¼ÆÊý¡¢²âËٵȴ«¸ÐÓá£
Ö÷Òª¾­Óª²úÆ·²¿·ÖÈçÏ£º
ʨÍþ`LIONPOWER`½Ó½ü¿ª¹Ø ·½ÐÍ SN04-N£¨N2£©£¬P£¨P2£©
PL-05N,P
TL-Q5MC1
£¨B1£©
½»Á÷½Ó½ü¿ª¹Ø ·½ÐÍSN04-Y
½Ó½ü¿ª¹Ø ±íÃæ±âƽÐÍ·½ÐÍW-O5N,P,
12mm
Ô²ÖùÐͽӽü¿ª¹ØLP-12N¡¢£¨NC£©,P£¨PC£©4C
18mm
Ô²ÖùÐͽӽü¿ª¹ØLP-18N¡¢£¨NC£©,P£¨PC£©8C
½»Á÷½Ó½ü¿ª¹Ø Ô²ÖùÐÍLP-18Y8C£»LP-12Y4C
12mm
ÂñÈëʽԲÖùÐͽӽü¿ª¹ØLP-12MN¡¢£¨NC£©,P£¨PC£©2C
18mm
ÂñÈëʽԲÖùÐͽӽü¿ª¹ØLP-18MN¡¢£¨NC£©,P£¨PC£©5C
½ø¿Ú²ÄÁÏ·ÀÀ×ÐÍÔ²ÖùÐͽӽü¿ª¹ØLP-12KN£¨NC£©,P£¨PC£©4C
½ø¿Ú²ÄÁÏ·ÀÀ×ÐÍÔ²ÖùÐͽӽü¿ª¹ØLP-18KN£¨NC£©,P£¨PC£©8C
½ø¿Ú²ÄÁÏ·ÀÀ×Ðͽӽü¿ª¹Ø ·½ÐÍSN04-KN£¨N2£©£¬P£¨P2£©
TK-Q5MC1
£¨B1£©
¹«Ë¾Ãû³Æ£º ¹ãÖÝÊÐÍþºãµç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 020 61137055 / »Æºì
ÊÖ»ú£º 13662333952
µØ Ö·£º ¹ãÖÝÊÐÔ½ÐãÇøÖÐɽÎå·193ºÅ
ÓÊ ±à£º 510120
Ö÷ Ò³£º http://www.gzplc.com
  • ¹¤³§ÅÅÎÛϵͳWWC202µçÈÝʽҺλ¼ì²â
  • ũҵ×Ô¶¯½½¹àWWC201µç×Óʽˮλ¿ØÖÆÆ÷
  • Óã¸×ˮλ×Ô¶¯¿ØÖÆWWC301H
  • µçÌݼ¯Ë®¾®Ë®Î»¿ØÖÆWWC2401
  • µØÏÂË®×Ô¶¯ÅÅË®WWC102µç×Óʽˮλ¿ØÖÆÆ÷
  • Ë®Ëþ×Ô¶¯¹©Ë®WWC101µç×Óʽˮλ¿ØÖÆÆ÷
  • Èýˮλ¿ØÖÆÆ÷BZ301L
  • Èýˮλ¿ØÖÆÆ÷BZ303
  • ˫ˮλ¿ØÖÆÆ÷BZ205
  • ËÄˮλ¿ØÖÆÆ÷BZ404
