Form Factor |
MicroATX Motherboard |
Processor |
Intel® Core8482; i7 / i5 / i3 Mobile processor
Package Type: rPGA988 |
Memory |
2 x DDR3 800/1066 SO-DIMM up to 8GB |
Chipset |
Mobile Intel® QM57 Express chipset |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with internal timer for 1min/s ~ 255min/s |
Power Management |
ACPI 2.0 compliant |
Serial ATA Interface |
6 x Serial ATA II interface up to 300MB/s. Support RAID 0/1/5/10
6 x Serial ATA I interface up to 150MB/s |
VGA Interface |
Integrated Intel® HD graphics Controller (depends on CPU). |
LVDS Interface |
24-bit dual channel LVDS interface |
| DVI Interface |
Optional DVI interface ( MS-C71XD ) |
Audio Interface |
Intel® integrated QM57 with Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82574L Gigabit Ethernet Controller |
| SSD Interface |
1 x Compactflash socket |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extended Interface |
PCI-Express X16 & X4 slot, 2 x PCI , Mini-PCIe & Mini-PCI socket. |
Internal I/O Port |
3 x RS232, 1 x GPIO, 1 x CDIN, 1 x SMBus, 1 x LPT, 1 x LVDS
1 x Audio, 1 x IrDA, 8 x USB2.0, 1 x DVI ( optional ) |
External I/O Port |
1 x PS/2 keyboard/mouse, 2 x RJ45 LAN, 1 x VGA, 4 x USB2.0,
1 x Audio, 3 x COM, 1 x SPDIF |
Power Requirement |
Standard 24-pin ATX power supply |
Board Dimension |
244mm x 244 mm (L x W) |
Temperature |
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC |
