PC3000
Production Process System
ÀíÏëµÄ:
¼¯³ÉµÄËÜÁϼ·³öϵͳ °ëµ¼Ìå - Diffusion & MBE ÈÈ´¦Àí- ÍêÕûµÄ¯×Ó¿ØÖÆ, Õæ¿Õ¯, ËíµÀÒ¤, Èȼ·Ñ¹ ʳƷ- ¿¾Â¯
Ò»¸ö¶àÓÃ;¼¯³ÉÄ£¿é»¯µÄ¿ØÖÆÏµÍ³£¬²ÉÓøßÉú²úÁ¦µÄ±à³Ì¹¤¾ßºÍIEC1131-3±à³ÌÓïÑÔ¡£ |
I/O Ä£¿é:
Ä£ÄâÁ¿ÊäÈëx 4: mV, T/C, mA, PT100 (indiv. channel isolation and CJC)
Ä£ÄâÁ¿Êä³ö x 4: mV, V
Êý×ÖÁ¿ÊäÈë x 14: 24V dc, 240V ac, vfc.
Êý×ÖÁ¿Êä³ö x 12: Relay 1A, Logic
CPU: 68020 w/Floating Point co-processor - LCM-Plus with 3 serial ports (RS422/RS485/RS232)
¹¤×÷ÎÂ¶È 0-50¡ãC Ïà¹ØÊª¶È: 5 to 95% non-condensing
µçÔ´: 85-264V ac
°²×°: 3U 19' rack (12 modules) panel or bulkhead |
¾«È·µÄÄ£Äâ¿ØÖÆ
Universal direct sensor inputs with 14-bit resolution. Highly configurable PID control - heat only, heat cool, auto & least squares adaptive tuning, single loop, cascade, ratio, valve positioner and more.
Êý×ÖÁ¿¿ØÖÆ
²¼¶ûºÍ×éºÏÂß¼¹¦ÄÜ
˳Ðò¿ØÖÆ
˳Ðò¿ØÖÆÍ¼ (SFC)
²ßÂÔ¿ØÖÆ
Built-in calculation of SPC variables, standard deviation, mean, upper and lower control limits and more Ability to use this information for real time Statistical Quality Control (SQC)
ͨѶ
Two user defined and one configuration port Expandable to 16 using the Intelligent Communications Module (ICM) Many Function Block selectable protocols - Ei-Bisynch, Modbus RTU master & slave, Siemens 3964R, Allen-Bradley Simple DIY driver for ASCII interfaces |
