欧陆EUROTHERM 808/818 精确温度控制器/编程器
808/818 精确温度控制器/编程器已经停止生产,现在用新型号3504/3508代替,咨询电话:020-32389052
818 精确的温度控制器和程序控制器 96W x 96H x 219D mm
应用为: 单区或多区的炉子,扩散炉,测试炉,高温灭菌,环境舱 |
采样频率: 8 times per second
供电电源: 85 to 264Vac, or 20 to 40V dc/ac
消耗功率: 8.5 watts
工作温度: 0 - 55 °C
相对湿度: 0 to 90% non-condensing
输入选择: 31 Different sensor linearisations + square root & linear
输出选择: Relay, logic, triac, or DC analogue
防护等级: IP54
The model 818 is a 1/4 DIN, Temperature/Process Controller or Temperature/Process Programmer. With a range of 'Plug In' modules and Software Configuration the 818 series can be made to cover most applications. The 818S offers single loop PID control, while the 818P/P4/P15 give the ability of running complex profiles.
The features include: Self and adaptive tuning Dual display
Choose from: Heat/cool/motorised valave outputs Up to 2 alarms Ramp to setpoint feature on 818S, 1 stored program of 8 ramps and 8 dwells on 818P, 4 stored programs of 8 ramps and 8 dwells on 818P4, 15 programs of 8 ramps and 8 dwells on 818P15. Auto/manual operation.
818 产品扩展
818S-MPC Melt Pressure Controller For Plastics Extrusion
- Designed for melt pressure control or melt pump inlet pressure control
- Analog retransmission of measured value, setpoint, error or output level to a chart recorder
- Adjustable output accel/decel rate limiting
- Incorporated transducer excitation power supply
- Front panel, push-button calibration of strain gauge
- Two fast-acting alarm outputs
818CP 热处理碳势控制
- 与标准氧探头匹配
- 0.10% 到 2.00% 碳势控制
- 可记录的模拟传送信号
- 可插入报警和通讯板
