欧陆EUROTHERM 变频器 ERCFW11 系列
Power Ratings:
1.1kW (1.5HP) – 2.2kW (3.0HP) @ 200Vac – 240Vac, 1-phase
1.1kW (1.5HP) – 30kW (40HP) @ 200Vac – 240Vac, 3-phase
1.5kW (2.0HP) – 370kW (500HP) @ 380Vac – 480Vac, 3-phase
ERCFW-11M up to 1900kW/2500HP air cooled or 2100kW/2800HP water cooled
Plug and play option modules
Standard Soft PLC with PLC and Function Block(ladder) programming for advanced functionality
Standard IGBT Brake switch for all models up to 45kW (Frame Size: D)
Optional for models from 55kW up to 110kW (Frame Size: E)
External Dynamic Braking Module available for models >110kW
Multi language support
Safety stop feature in compliance with EN 954-1, Category III
Versatile communication support
Standard Memory module for parameter/program storage
Large number of Analogue and Digital I/O for system ingration
Internal DC choke standard
Internal EMC filter optional for all models up to 45kW (Frame Size: A – D)
Standard for all models from 55kW up to 370kW (Frame Size: E – G)
Available in IP20 and IP54 protection class
Standard software with the following control functions: V/Hz, Sensorless Vector, Closed Loop Vector and Permanent Magnet (PM) Motor control
Standard USB port for Programming/Monitoring
Meets IEC61000-3-12 standard for low current harmonics
Internal PID Loop
Compact Modular Inverter design (Model: AFW11M) for high power ratings up to 2100kW (2800HP) in both Air Cooling and Water Cooling version
Accurate speed sychronization function
应用:
离心泵
过程泵
风扇/排气
搅拌器/搅拌机
出模机
转出工作台
干燥机
旋转滤网
切割机
